Old 01-16-2012, 10:28 AM
heiner heiner is offline
Default Error commuicating with digishoetool - please help
Im having this error: problem to communicate with digishoetool -9169.
it suggests a new install
i did a clean uninstall of pro tools 9.05
i did reinstall pt 9 , this worked. updated to pt 906 - same error again. it only happens at second start. on first start i dont get into the open session dialog and pro tools hangs. pt 9.0 worked on second start too
i did update from 1064 on 1068 and now to pro tools 10, there is the same error again
(system: macpro)
Old 02-01-2012, 02:12 PM
mpeg5 mpeg5 is offline
Default Re: Error commuicating with digishoetool - please help
Same here. I installed the update to 10.0.1 and my system is unusable.
De and reinstalled 3 times now... same [bleep][bleep][bleep][bleep].
Have too many problems with Pro Tools software in the last weeks... i really think to jump on new software that works and costs less... sorry AVID, you fail too often in the last months.
Old 02-01-2012, 03:25 PM
PaulV's Avatar
PaulV PaulV is offline
Hi there,
Sorry you're having trouble with this. One thing that can cause this error is improper permissions in certain folders.
Give this a try, from the Finder:
  1. Navigate to /Library/Application Support, and find the Avid folder.
  2. Right click on the Avid folder and choose Get Info.
  3. Expand the Sharing and Permissions triangle, and click on the lock in the lower right corner (entering password as needed)
  4. Make sure all permissions in the list are set to "Read and Write"
  5. Click the gear and do "apply to enclosed items" and hit OK
I hope that helps.
Cheers,
Paul Vercellotti
Avid Engineering
Old 02-18-2012, 11:44 AM
philip888's Avatar
philip888 philip888 is offline
Originally Posted by PaulV View Post
Hi there,
I hope that helps.
This changed nothing any other ideas?
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7
Old 06-28-2012, 10:05 PM
bobbyjanesounds bobbyjanesounds is offline
I had the same problem. I figured it out.
Go to /Library/Application Support/ Avid folder / Pro Tools folder
You should then see in the Pro tools folder - the DigiShoeTool
Right click - Get info
Change Sharing/Permission settings to read and write (may need to unlock it first)
Once changed all to read and write lock it and close
Thats it - it worked for me, no problems.
Hope this helps
Old 10-07-2012, 07:24 PM
filmcomposer filmcomposer is offline
Paul,
Mac dual quad 3ghz 4mb ram Late 2008 MAC desktop 10.6.8 PT LE 8.0.5 all was working fine until I installed KOMPLETE 8 had KOMPLETE 7 no prob but K- 8 I too have the digi shoe tool error. Every time I restart computer and reboot PT I get the error. Recently I did not have to reset the permissions probably because I used Tech Tool on the drive to fix permissions. PT works after I trash the prefs but I still have to do it every time....is there a fix for this? I just trashed all the native instruments plists....help, I have to do BS work everytime before I start working and I'm afraid that when I start it and go through this ritual it may not work... BTW, I am a working composer and need to be able to work!
Thanks, Steve
Old 10-18-2012, 12:20 PM
Paul,
Thanks, Steve
Old 10-15-2013, 05:44 PM
waynekhin waynekhin is offline
Thank you, I had similar problem after installing the AAX plugins for AIR Instruments. It seems to work now.
Wayne Khin
www.homestudio.com.sg
www.homestudiomusic.com
Old 11-10-2013, 08:53 AM
Helge Krabye Helge Krabye is offline
Hope this helps
Thanks for sharing this! It seems to have solved my problem (which I got after installing the Native Instruments AAX update). It's quite disappointing that Avid didn't share this important info in their support area, as we are many with this problem.
Helge Krabye
Official artist page: Homeless Balloon
Old 12-11-2013, 09:53 PM
bernsense bernsense is offline
It does seem to have something to do with the AIR instruments. Installed them today, and all of a sudden, that permissions error comes up in PT 10
petting:zoo Music, Inc.
Topanga, CA
http://www.facebook.com/pettingzoomusicinc
Mac Pro 2019 Pro Tools HDX;
2x Lynx Aurora, 1x 192 I/O
'Only because you ARE a character doesn't mean you HAVE character' - The Wolf
Please rock!
DigiShoeTool? LoL Productions snc Pro Tools TDM Systems (Mac) 8 01-25-2015 11:35 AM
digishoetool error woof Pro Tools 10 7 12-22-2013 08:43 PM
Pro Tools 9 Playback Error Lead to DAE Error 743 Which Lead to A CPU Overload Error EricMulhern macOS 1 11-20-2011 05:39 PM
Error type 10,address error ,illegal error, buss error ,illegal instruction KasticK Pro Tools TDM Systems (Mac) 3 05-14-2003 11:21 AM
Buss error,Address error,ilegal instruction,error type 10 KasticK Pro Tools TDM Systems (Mac) 1 02-08-2003 05:49 PM
