Old 01-29-2011, 09:24 AM
goga goga is offline
Question ADC shows red. What to do?
ADC has to much to handle and shows red in the nr of samples. What to do?
That is pretty much the question. It shows red on both chanells I'm using reverb plugs.
Old 01-29-2011, 11:56 AM
Default Re: ADC shows red. What to do?
How much too much? You get better answers with more detail. Are you on LONG or SHORT ADC? What are the numbers? If its beyond the LONG capacity(I think that's 4096 samples), then ADC won't compensate, but for reverb plugins, that's usually not an issue. By running Reverb on an AUX track and sending to it, you can simply shorten the pre-delay and set the reverb for 100% wet and then you should not have any issue with latency.
Old 01-29-2011, 03:40 PM
DJ Hellfire DJ Hellfire is offline
If your plugin is causing more than 4096 samples of delay, you're probably gonna have to use the timeadjuster plugin to pick up the slack, or nudge your tracks the amount of samples they are latent, or use a different plugin.
I would highly suggest against nudging unless you take note of exactly where the regions originally were. From my experiences, certain plugins, like PSP Vintage Warmer, caused a lot less latency after I updated the plugin. For example, when I had version 2.0, it caused like 1400 something samples of latency. Updated to 2.3 and the latency is now only 631 samples. So all sessions I used that plugin, I have to readjust everytime adjuster when I revisted the session. IMO, that is much easier than trying to figure out where the regions belong.
If you do nudge, I know there is a way to move regions back to the exact position they were recorded at. I forget how to do it, but it's in the manual...somewhere!
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
TDM Mix plus 3, I can't see the 24 I/Os only shows 16 soundblaster Pro Tools TDM Systems (Mac) 2 05-20-2008 12:57 PM
Mp3 encoder always shows 44.1 Peter Groom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-25-2006 10:18 AM
Midi I/O shows up when it want to MR808 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-12-2005 02:38 PM
OT: My 120 GB HD only shows up as 30 GB.. PLZ help metaltim 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-10-2005 04:39 PM
ok i have BFD and it only shows up as a rewire samrisio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-31-2004 01:34 PM
