Old 12-03-2009, 07:52 AM
jimlongo's Avatar
jimlongo jimlongo is offline
Default Re: Pro Tools Video Output Options Compendium
Regarding #7, Blackmagic Cards in the same computer as Protools.Is this really approved? I thought these cards were approved only for VSattelite use.
I ask because I'm still using an Aurora FuseX in a PCIx setup, and would be interested in the same approach if I moved to a newer computer/system.
Richard (or anyone else), how does this work in regards to consistent frame accurate start?
Thanks,
jim
noise | jimlongo
Old 12-03-2009, 04:09 PM
DGould DGould is offline
Hi Jim,
Yes, that is correct - Blackmagic cards are approved for use with Pro Tools on a Mac Pro, either installed in the actual Pro Tools system, or configured as a Video Satellite LE. It will give you a very similar setup to what you have currently with your Aurora card.
See here for more compatibility information: http://www.digidesign.com/index.cfm?...5&itemid=36632
Regarding Frame Accurate Start, assuming you are on an HD system and using the Blackmagic Decklink card, you can lock both to video reference to guarantee frame sync.
I hope that helps.
David
David Gould
Product Manager - Audio Post Production
Old 12-03-2009, 04:51 PM
jimlongo's Avatar
Thanks David.
noise | jimlongo
Old 12-03-2009, 04:56 PM
tom_lowe tom_lowe is offline
Actually, this is the case for all CODECs, as there is no on-board hardware for decoding, unlike AJA and the old PipePro cards.
However all most Mac Pros will deal with all QuickTime CODECs with minimal effort, apart from un-compressed HD... obviously.
Originally Posted by nucelar View Post
7. Blackmagic PCI Card
CONS: for certain codecs, it uses CPU Power for video decoding.
Old 12-03-2009, 11:47 PM
BScout BScout is offline
I think to keep this post more universal for all post folks, the options that are available for PC (windows) usage should be noted. From what I see, 1, 3, 4, 5, & 6 can be done on a PC. I don't know about 7 & 8. I know 2 cannot.
  #16
Old 12-04-2009, 02:01 AM
nucelar's Avatar
nucelar nucelar is offline
thanks again for the contributions.
Added PC compatibility and minor corrections.
  #17
Old 12-14-2009, 02:35 PM
koo_koo_bonkers koo_koo_bonkers is offline
Fantastic thread .. can digi please sticky ?
MacPro 5,1 - 2 x 2.66 6 core - 32G Ram - SSD's - Mac OSX 10.12.6 - HD Native Card - Omni - Focusrite RedNet 5 - Avid Dock - iPad2
  #18
Old 12-15-2009, 01:02 AM
bad jitter bad jitter is offline
1. QuickTime to desktop monitor
CONS: You only have one monitor left for Pro Tools.
True only if you are using only one video card. Many of us are successfully using two video cards for two or even three monitors for Pro Tools and one for picture.
  #19
Old 12-22-2009, 12:12 PM
adamjay adamjay is offline
Anyone know a good Quicktime to MXF converter?
  #20
Old 12-24-2009, 03:17 AM
Ale Ale is offline
Default Blackmagic PPC
Blackmagic on PPC
Original Decklink and Decklink Studio
Works perfectly under Protools 8.
Using jpeg codec you can even output HD material via SDI to hdlink
Simple output of DV is also no problem.
Protools 6 to 7.4 I had no luck!
Ale
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1)
1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+
HTML code is On
Can Matrox MXO2Mini be used for video output with Pro Tools? kd_special Post - Surround - Video 0 02-17-2011 05:53 AM
HDMI Video Output options ?? TommyT Pro Tools TDM Systems (Mac) 6 02-14-2010 02:12 PM
Video output options update request Craig F Post - Surround - Video 0 01-31-2007 06:24 PM
Video output options Pezzatronic Pro Tools M-Powered (Win) 4 10-12-2006 02:49 AM
Firewire video output options/solutions protooleriate Pro Tools TDM Systems (Mac) 5 01-23-2003 01:20 PM
