Old 11-05-2009, 06:50 AM
Table Syrup Records's Avatar
Table Syrup Records Table Syrup Records is offline
Default PT Mix - Power Card? Questions - It's a Mix Core labeled Power Card
Ok, so I have a card in my mix system that is unlike any I've seen.
It has a Mix Core sticker on it.
Serial and Peripheral connectors and card are laid out just like a Mix Core
Says POWER CARD on it.
Shows and Passes in Digitest as a Mix Core
Shows and functions in 6.4.1 Mix as a Mix Core
Is this a pre-mix release Mix Core???
I don't get it.
Is this card the same, identical, to a Mix Core? Same Specs?
Shorty: Table Syrup Records
Mac Pro 5,1 3.33 GHz Hex, 32GB
EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23"
OSX Sierra
Pro Tools HD 11.2.2
Waves IOS, IOX, STG2412
Extreme Server (x2)
Logic Pro X, DSP Quattro, Final Cut Pro X
Waves Mercury+SSL+AbbeyRoads
Trident S65 with embedded US-2400
Live:
2012 Mac Mini, Dual SSD, i7 2.4, 16GB
Win 10, OSX Sierra
LV1, MRSG
Hardware from above (same gear)
Dual Dell P2418HT Touch Screens
Waves Icon X (x2), M, with Screens
Custom enclosure
Old 11-08-2009, 11:28 PM
milesofwire milesofwire is offline
Default Re: PT Mix - Power Card? Questions - It's a Mix Core labeled Power Card
Yes I have seen that as well, it's the older cards that say that, they are the same as all other Mix cards, just an older revision I suppose.
Old 03-25-2013, 09:19 AM
JFreak's Avatar
JFreak JFreak is offline
Let me revive this old thread :) Does anyone still really remember this well enough?
My friend just called and said he bought a "MIX farm" card but the card motherboard said "POWER CARD" instead of "MIX CARD" which we have become used to. He also got an extra red mix card that said something like "SATCHMO" -- is this like a prototype card or what, anyone seen such card somewhere?
Should they just work together with a MIXplus system or was it money badly spent?
Janne
Old 03-25-2013, 09:41 AM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
I had a red Samplecell I got off of ebay. From what I've read, the red PC board just means that it was a pre-release version for testing. The red samplecell worked just like any other one I had, never had a problem with it.
I think the same is probably true of these "Power Card" mix cards. Possible that MIX cards were originally going to be called "Power Cards", then a marketing decision was made to change the name after production had begun. AFAIK all mix cards and d24 were made to the PCI 2.1 spec, so even the early revs should still work in any G4.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 03-26-2013, 12:13 AM
JFreak's Avatar
Okay...
So the green Power Card works fine, but the red card fails digitest every time, no matter the combination.
Oh well, it was extra card anyway so I guess he just throws it away
Janne
Old 03-26-2013, 06:16 AM
I wonder if the red card, being a beta card, was early enough to not be g4 compatible? It might actually work in a beige G3 or PM9600, this could have been one of the very first test versions ever made.
I'm kind of intrigued by it, I wonder if it has any functionality that release version mix cards did not? (Maybe it was initially designed to work with disk io core cards?)
- John
Old 03-26-2013, 11:13 AM
JFreak's Avatar
If you want to have it I may be able to convince my friend shipping it to you at your cost
Janne
Old 03-26-2013, 12:20 PM
Sure, let me know. I'm up for trying. I'm planning on putting together an old school tdm system again when I have some downtime, so I have a dedicated rig that can run some of my older TDM plugs.
- John
Old 03-27-2013, 05:13 AM
JFreak's Avatar
It seems this can be done. PM me the shipping details and you should probably get the card sometime in April
Janne
Old 03-27-2013, 07:53 AM
sunburst79 sunburst79 is offline
Just a guess but Digi products usually had a in house Project name. EG the Mac to Windows port was "Frank" after Frank Zappa. My guess is that the "Satchmo" card is probably a prototype. A buddy has a (the?) 96io prototype and its a rack box with a circuit board hanging off the front via standoffs. Its fairly crude but PT sees it as a 96Io. Its kinda funny since whomever silk screened the board put pictograms of guitars, trumpets and saxophones on it. I'll ask if he remembers anything about Sachmo cards.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
HTML code is On
Mix Vs HD Card Power? Ru_C Pro Tools TDM Systems (Mac) 10 09-27-2007 09:13 AM
power consumption of a HD core card? black030 Pro Tools TDM Systems (Win) 3 03-16-2007 09:18 PM
DSP Card and Farm Card: How much more Power? DC11 Pro Tools TDM Systems (Mac) 3 03-25-2004 06:35 PM
Power Mix+ 64 Card? Peter Duemmler General Discussion 3 06-24-2001 02:12 PM
what card for Power Book? Enis Presheva Jr. Pro Tools TDM Systems (Mac) 1 10-24-2000 04:51 AM
