Pro Tools 7.3.1cs7 Updates
Pro Tools HD, LE, and M-Powered v7.3.1cs7 updates for Mac and Windows are available for download from the Pro Tools CS Updates page (under Quick Links in the Support section)
www.digidesign.com/support/csupdates All 6 updates (HD, LE, M-Powered, Mac and Windows) include: Fixed: Pro Tools Automation Thinning Could Sometimes Remove Non-Redundant Breakpoints (Item #100794) - The thinning algorithm could mistakenly classify a breakpoint as redundant HD Mac/Win updates also include: Fixed: Playback of Surround Panning automation gets "stuck" (Item #100847) - This would only occur when writing automation with a selection highlighted while in Loop Playback mode Fixed: Trim Values Could Be Accidentally Written To The Entire Session (Item #100795) Steps to reproduce: - A fader position in Latch/Trim or Touch Trim could be accidentally bumped while the transport was stopped. - Subsequently leaving Trim mode, or manually coalescing trims would then write that bumped value to the entire track LE Mac/Win updates also include: Fixed: When Monitoring All Inputs on 003 Factory, Random Pops and Clicks Could Occur on Inputs 4-8 (Item #101084) - Although this is not likely to occur on 003 Rack, this update is recommended for both 003 Factory (console) and 003 Rack Pro Tools HD, LE, and M-Powered 7.3.1cs7 Updates — Downloads & Details Pro Tools HD 7.3.1cs7 for Mac OS X (Tiger) http://www.digidesign.com/index.cfm?...4&itemid=32370 Pro Tools HD 7.3.1cs7 for Windows XP http://www.digidesign.com/index.cfm?...4&itemid=32371 Pro Tools LE 7.3.1cs7 for Mac OS X (Tiger) http://www.digidesign.com/index.cfm?...4&itemid=32372 Pro Tools LE 7.3.1cs7 for Windows XP http://www.digidesign.com/index.cfm?...4&itemid=32373 Pro Tools M-Powered 7.3.1cs7 for Mac OS X (Tiger) http://www.digidesign.com/index.cfm?...4&itemid=32374 Pro Tools M-Powered 7.3.1cs7 for Windows XP http://www.digidesign.com/index.cfm?...4&itemid=32375
Administrator Avid Pro Audio Community |
Pro Tools 7.3.1cs7 Updates | Avid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-01-2008 03:31 PM |
Pro Tools 7.3.1cs7 Updates | Avid | Pro Tools TDM Systems (Win) | 0 | 07-01-2008 03:27 PM |
Pro Tools 7.3.1cs7 Updates | Avid | Pro Tools TDM Systems (Mac) | 0 | 07-01-2008 03:26 PM |
Pro Tools 7.3.1cs7 Updates | Avid | Technical Alerts | 0 | 07-01-2008 03:24 PM |
Pro Tools HD 7.1cs7 Updates | Avid | General | 0 | 05-09-2006 10:58 PM |
