Closed Thread
Old 07-01-2008, 03:27 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools 7.3.1cs7 Updates
Pro Tools HD, LE, and M-Powered v7.3.1cs7 updates for Mac and Windows are available for download from the Pro Tools CS Updates page (under Quick Links in the Support section)
www.digidesign.com/support/csupdates
All 6 updates (HD, LE, M-Powered, Mac and Windows) include:
Fixed: Pro Tools Automation Thinning Could Sometimes Remove Non-Redundant Breakpoints (Item #100794)
- The thinning algorithm could mistakenly classify a breakpoint as redundant
HD Mac/Win updates also include:
Fixed: Playback of Surround Panning automation gets "stuck" (Item #100847)
- This would only occur when writing automation with a selection highlighted while in Loop Playback mode
Fixed: Trim Values Could Be Accidentally Written To The Entire Session (Item #100795)
Steps to reproduce:
- A fader position in Latch/Trim or Touch Trim could be accidentally bumped while the transport was stopped.
- Subsequently leaving Trim mode, or manually coalescing trims would then write that bumped value to the entire track
LE Mac/Win updates also include:
Fixed: When Monitoring All Inputs on 003 Factory, Random Pops and Clicks Could Occur on Inputs 4-8 (Item #101084)
- Although this is not likely to occur on 003 Rack, this update is recommended for both 003 Factory (console) and 003 Rack
Pro Tools HD, LE, and M-Powered 7.3.1cs7 Updates — Downloads & Details
Pro Tools HD 7.3.1cs7 for Mac OS X (Tiger)
http://www.digidesign.com/index.cfm?...4&itemid=32370
Pro Tools HD 7.3.1cs7 for Windows XP
http://www.digidesign.com/index.cfm?...4&itemid=32371
Pro Tools LE 7.3.1cs7 for Mac OS X (Tiger)
http://www.digidesign.com/index.cfm?...4&itemid=32372
Pro Tools LE 7.3.1cs7 for Windows XP
http://www.digidesign.com/index.cfm?...4&itemid=32373
Pro Tools M-Powered 7.3.1cs7 for Mac OS X (Tiger)
http://www.digidesign.com/index.cfm?...4&itemid=32374
Pro Tools M-Powered 7.3.1cs7 for Windows XP
http://www.digidesign.com/index.cfm?...4&itemid=32375
Administrator
Closed Thread
Pro Tools 7.3.1cs7 Updates Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-01-2008 03:31 PM
Pro Tools 7.3.1cs7 Updates Avid Post - Surround - Video 0 07-01-2008 03:29 PM
Pro Tools 7.3.1cs7 Updates Avid Pro Tools TDM Systems (Mac) 0 07-01-2008 03:26 PM
Pro Tools 7.3.1cs7 Updates Avid Technical Alerts 0 07-01-2008 03:24 PM
Pro Tools HD 7.1cs7 Updates Avid General 0 05-09-2006 10:58 PM
