Old 05-22-2008, 03:05 PM
req06 req06 is offline
Default More errors when clocking from external AD/DA...DIGI PLS HLP
Hi Guys,
I have recently added an RME ADI-2 to my 002r setup. I was getting persistent error messages today (lower H/W buffer etc) when clocking from the adi-2. It was really annoying and in the end I switched back to internal since I had a client waiting. I have by no means done lots of testing with the adi-2 but I do like what I hear from it.
The interesting thing is that none of the errors referred to an invalid clock choice, but I am wondering if clocking to an external device taxes PT more thereby causing issues with H/W buffer etc.
I just would like some thoughts on the reliability (or otherwise) of clocking to external ADDA's?
I'm running G5, 002r, PT 7.4cs3
THX
G5 dp 2.0Ghz, 2.5 gb RAM/ G4 Powerbook 15" 1.33mhz, 2gb RAM/ 002r/Lacie D2 FW800/PTLE 7.4
Old 05-22-2008, 03:17 PM
DigiTechSupt's Avatar
Default Re: More errors when clocking from external AD/DA
What are the error numbers you're getting?
Avid Audio Tech Support
Support FAQ
Old 05-23-2008, 09:44 PM
dubaifox dubaifox is offline
I had this same problem when clocking my 002r to my Rosetta 200.
Finally gave up and used Digital Performer.
I can't remember what the error numbers were but it was mentioned in the message that the problem could be a clocking error.
International Award Winning Arabic Fusion
www.ajmusiconline.com
2xMacPro 2.66,002r,OSX 10.4.10,PT 7.4cs8
3xVisionDaw,NI Komplete,Yamaha 01V/96
Old 05-24-2008, 09:26 AM
-6085 messages n various songs with different h/w buffer settings.
I have used the preferences trasher (and emptied the trash)
Its strange as I am able to monitor through the RME D/A, so its not as if its rejecting it outright.
Any ideas?
Old 05-25-2008, 03:08 AM
Bump.
Just to add a few details:
I am running PTLE 7.4 CS4 (the latest one I think?)
I have used my Lacie via a FW800 in the past with no problems, but it seems recently to cause issues, so as of now I am running it via FW400 (back port of G5)
002r via front FW port, cable length about 3 foot (I have used this cable for the past year with no issues)
I am wondering if installing a new FW PCI card will help, so that the drive and the interface are on different buses?
Anyway, would appreciate some feedback, surely It is possible to use an external AD/DA effectively with the 002?
THX!
Old 05-27-2008, 04:49 AM
Bump.
Any help or ideas would be greatly appreciated Tech Suppt.
THX
Old 05-27-2008, 02:41 PM
bump to get the USA reaction
Old 05-27-2008, 03:00 PM
stoneinapond stoneinapond is offline
...Anyway, would appreciate some feedback, surely It is possible to use an external AD/DA effectively with the 002?
THX!
Being doing it for several years now, trouble free mostly with a Rosetta 800 and a G5.
I do run the 002R and my drives on the two separate FireWire connectors (front and back).
Old 05-28-2008, 10:47 AM
Ok So it is possible AND viable then.
Digitech could you respond please?
THX
Aggregate IO clocking errors digital distorion Dhammer Pro Tools 10 2 10-07-2013 02:47 PM
URGENT HELP NEEDED, Clocking cause assertion errors MrBibidy macOS 0 06-19-2012 10:49 AM
G5 optical into 192 - Distortion & Clocking errors Polaris Post - Surround - Video 12 11-22-2006 11:10 AM
External clocking of PT nqmike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-20-2004 05:08 PM
Clocking errors , need help!! JasonAaronAdams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-17-2004 06:46 AM
