Old 12-16-2004, 11:40 PM
JasonAaronAdams JasonAaronAdams is offline
Default Clocking errors , need help!!
Ok, here's the deal:
I recorded a band last week using my 002 and octopre. I was using the external clock via adat optical set at 48k. I sold the octopre on ebay and bought an used m80. so heres the problem. for some reason, pro tools will not let the internal clock in the digi to open the files at 48k, and instead, opens them at 44.1. When i try to switch it under the hardware tab, it just reverts back to 44.1.
Is there a way I can open these files correctly, without using an external clock?
"Excuse me while I whip this out"
Old 12-17-2004, 06:46 AM
Camilo Toledo Camilo Toledo is offline
Default Re: Clocking errors , need help!!
Try the original files in a new session. Export the session data to a new session, and set the clock to internal, and then import all audio to the new session.
Camilo Toledo
Aggregate IO clocking errors digital distorion Dhammer Pro Tools 10 2 10-07-2013 02:47 PM
URGENT HELP NEEDED, Clocking cause assertion errors MrBibidy macOS 0 06-19-2012 10:49 AM
More errors when clocking from external AD/DA...DIGI PLS HLP req06 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 05-28-2008 10:47 AM
G5 optical into 192 - Distortion & Clocking errors Polaris Post - Surround - Video 12 11-22-2006 11:10 AM
errors errors errors Please digi tech guys help me dunkyj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-11-2005 01:19 PM
