  #261
Old 07-11-2021, 12:50 AM
Malkout Malkout is offline
Default Re: Protools 2021.6
Originally Posted by Obsidian Dragon View Post
To make sure I understand. When you freeze a track, does the delay compensation just change the delay time of the plugin incorrectly or does it change the change the overall plugin's effect on the track (not just timing)? I haven't play around with this very much, but I'm not noticing the difference when freezing a track. Perhaps someone more experienced with this process can chime in and verify.
I meant when the daw is freezing due to last update bug. Its shifting some tracks loaded with some heavy plugins, as well as UAD plugins.
  #262
Old 07-11-2021, 02:42 AM
Jess Davy Jess Davy is offline
Default Re: Pro Tools 2021.6
Originally Posted by musicman691 View Post
The pan slider has been a square since PT2020.12 and maybe earlier. I like it as a square - much easier to grab.
Really, never noticed it before
Website: www.peakattackstudios.com
YouTube: www.youtube.com/peakattackstudios
iMac Pro 3.2 Ghz 8 Core Intel Xeon W • 32GB 2666 MHz DDR4 • Amphion Two15 w/ Amphion Amp500 • UAD Apollo 8 Duo • UAD-2 Satellite Quad • Avid Artist Mix • Kemper Profiling Amp • BSS DPR-402 Stereo Compressor • Pro Tools 2023.12.1 • MacOS 14.3.1
  #263
Old 07-16-2021, 07:37 AM
innerbooty innerbooty is offline
Running 2021.6 with HDX on Mojave here, 5,1 flashed Mac Pro. Had been mostly stable after some initial growing pains, this being a new system. But just posted elsewhere about a sporadic issue where I will load up a (very small) session, press play (using spacebar or transport) and it will not play. Not accidentally set to "Online". Just won't play. Have had to reboot to get it working, although today just quitting and reloading Pro Tools worked. FWIW, I had just installed McDSP Emerald Pack demo. Also, while checking out McDSP Revolver plugin I had my first GUI freeze, just trying to toggle between settings on the plugin. Mouse frozen, but no beachball. Thought I was completely frozen, but cleared up in about 3-4 seconds. Unnerving. Although that being said, I recently brought up a fairly involved mix in progress from PT 10 HD2 Accel, and it came up great in 2021.6 and I was able to finish it with no major issues - except for a couple of issues with Valhalla plugins
2009 Mac Pro 5,1, PT 2021.3.1, HDX, Mojave, RX 560, Apogee AD/DA-16X, HD I/O 8x8
  #264
Old 07-17-2021, 12:03 PM
audiogamble audiogamble is online now
Have any M1 users had luck solving this issue yet, aside from rolling back their pro tools version? I would love to have access to the extra io that this version offers.
  #265
Old 07-19-2021, 10:44 AM
john1192 john1192 is offline
i decided to move all plugins to unused folder, and let pro tools rebuild all the AVID plugins .. that seemed to help my Beach Balling .. on my system, it appears to be a PLugin issue .... Softtube was one that gives me trouble as they are not M1 compatible yet ... someone suggested doing something with OPEN GL on the plugins themselves, i am researching that ..
just a couple 2 cents !!!
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
  #266
Old 07-19-2021, 12:51 PM
bad jitter bad jitter is offline
Okay then, sorry if you felt offended. Just generally speaking it is not nice to read about Avid's new features on PTE before release notes on avid.com
You’re wrong. It is very nice, indeed. It’s the raison d’être of PTE.
  #267
Old 10-02-2021, 10:43 AM
mirovaz mirovaz is offline
GUI also freezes frequently here. Running MacBook Pro M1 16G.
Hope they solve this ASAP
MacBook Pro M1 16G RAM
OSX Big Sur 11.6
ProTools 2021.10
UA OCTO Thunderbolt, UAD Twin MK2 QUAD
  #268
Old 10-02-2021, 10:59 AM
Running PT 2021.6 isn't helping you any. Will be a long time before PT goes native on Apple silicon.
Recommended iMac Specs for Pro Tools 2021.3 (Pro Tools STANDARD) BigSur Compatibility Spoil the Child macOS 19 04-05-2021 05:35 PM
Pro Tools First 2021.3 is out Netmania Pro Tools | Intro Discussion 2 04-02-2021 01:26 PM
