Can Anyone Tell Me????
Is there a controller map for PT/LE? I just got a Tascam TM-D1000 and I'd like to use it as a control surface for the 001.
WLTruesongs |
Re: Can Anyone Tell Me????
Unless you can get one out of DIGI, there is no controller map. You just have to try all the existing codecs and see if one works. Or, pick one that supports the numbr of channels you want to control at one time and then see if you can map the Tascam to it by trial and error.
See Appendix A: "Using Other MIDI Control Surfaces" in the MIDI Control Surfaces Guide. Installed on your hard drive in the Release Notes & Documentation folder, or available from the Technical Document Library.
Administrator Avid Pro Audio Community |
