9092, 9093 and 9129 error update?
I have been experiencing the dreaded 9092 9093 and 9129 errors that are all documented on here. All I am doing is recording a single naked track and they come up within seconds.
Avid, has any progress been made with regard to this issue? While talking to Avid Tech Support on the phone, I tried uninstalling all 3rd party plugins, trashing the prefs + databases, and repairing the permissions. Also checked to make sure i did all the optimizations. This allowed me to track and playback... just long enough for the call to end, then started up again (my luck ). But while talking to the rep, he mentioned there was a possible BIOS settings configuration I can try, anyone familiar with this? And just for clarity, originally I was receiving error -9093 and another error that said 'problem detected with audio clock. check that your clock source and sample rate are correct'. After I reconfigured everything, 9129 and 9092 started propagating. Don't know if this matters. SiSoftware Sandra Computer Model : GigaByte Z68XP-UD5 Workgroup : WORKGROUP Host Name : TactikAudioPC User : Joey Processor Model : Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz Speed : 3.8GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing Computer Mainboard : GigaByte Z68XP-UD5 BIOS : Award (OEM) F1 05/31/2011 Bus(es) : X-Bus PCI PCIe USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : No Total Memory : 16GB DIMM DDR3 Chipset Model : Intel Core (Sandy Bridge) DRAM Controller Front Side Bus Speed : 100MHz Total Memory : 16GB DIMM DDR3 Channels : 2 Memory Bus Speed : 2x 667MHz (1.33GHz) Memory Module(s) Memory Module : Corsair CMZ16GX3M4A1600C9 4GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMZ16GX3M4A1600C9 4GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMZ16GX3M4A1600C9 4GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMZ16GX3M4A1600C9 4GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Video System Video Adapter : NVIDIA GeForce GTX 560 (336 SM5.0 1.7GHz, 1GB 4.1GHz, PCIe 2.00 x16) Graphics Processor OpenCL GP Processor : NVIDIA GeForce GTX 560 (336SP 7C 1.7GHz, 1GB 4.1GHz) Compute Shader Processor : NVIDIA GeForce GTX 560 (336SP 1.7GHz, 1GB 4.1GHz) Compute Shader Processor : Intel(R) HD Graphics Family (6SP 850MHz, 64MB DDR3 1.33GHz 128-bit, Integrated Graphics) CUDA GP Processor : NVIDIA GeForce GTX 560 (336SP 7C 1.7GHz, 1GB 4.1GHz) Storage Devices WDC WD1500HLFS-01G6U0 (150GB, SATA300, 3.5", 10000rpm, 16MB Cache) : 140GB (C:) Seagate ST3500320AS (500.1GB, SATA150, 3.5", 7200rpm) : 466GB (E:) LITE-ON DVDRW LH-20A1S (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices Hard Disk (C:) : 140GB (NTFS) @ WDC WD1500HLFS-01G6U0 (150GB, SATA300, 3.5", 10000rpm, 16MB Cache) Hard Disk (E:) : 466GB (NTFS) @ Seagate ST3500320AS (500.1GB, SATA150, 3.5", 7200rpm) Optical Drive (D:) : N/A @ LITE-ON DVDRW LH-20A1S (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Giga-Byte Cougar Point LPC Controller LPC Legacy Controller 1 : T2 87-28 Audio Device : Giga-Byte Cougar Point High Definition Audio Controller Audio Device : EVGA 0E0Ch Audio Codec : nVidia 0016h Audio Codec : nVidia 0016h Audio Codec : nVidia 0016h Disk Controller : Giga-Byte Cougar Point 4 port SATA IDE Controller Disk Controller : Giga-Byte Cougar Point 2 port SATA IDE Controller Disk Controller : Giga-Byte 91xx SATA 6G Controller USB Controller 1 : Giga-Byte Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : Giga-Byte Cougar Point USB Enhanced Host Controller #1 USB Controller 3 : Giga-Byte Renesas Electronics USB 3.0 Host Controller FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 5.9
Dwight, you ignorant slut |
Re: 9092, 9093 and 9129 error update?
Try disabling this in BIOS
Compute Shader Processor : Intel(R) HD Graphics Family (6SP 850MHz, 64MB DDR3 1.33GHz 128-bit, Integrated Graphics) Integrated graphics can be a show stopper(why I never recommend a Z68 motherboard).
Oh, wow. When I was researching motherboards, newegg gave me misinformation! it said that my motherboard did not have integrated graphics on it. If I knew this motherboard did, I would not have bought it.
I disabled the integrated graphics but the 9093 error popped up when I tried to test it. Do I have to reinstall Pro Tools for the configurations to take effect? I would prefer not to have to do uninstall, because last time I installed I had a firmware nightmare with the native card and I am not sure if uninstalling would wipe the firmware from the card.
I doubt a re-install on PT will matter, but its always a good idea to trash prefs after changing computer settings.
ok. i wish i knew you never reccomend z68 motherboards before I got it!
What motherboard would you reccomend?
9129, 9092, 9093 errors | Jack Ruston | Pro Tools HDX & HD Native Systems (Mac) | 187 | 12-23-2012 01:19 PM |
Error 9093 & 9092 please help!! | travis_123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-09-2010 07:02 PM |
Help! Errors 9092, 9093, 9094, 9129 persisting! | doobaGeoff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 05-27-2007 06:32 PM |
Interrupt errors -9092/ -9093/ -9094/ -9129 | saxbill | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-18-2002 11:41 AM |
Studied all posts on 9092 9093 9129 however, these errors are still driving me NuTs! | Wildberrie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 23 | 12-06-2001 05:10 AM |
