Old 01-28-2002, 07:28 PM
Jimmy_Vogt Jimmy_Vogt is offline
Default Reveals that hum
Am I doing something wrong. Why would I get a loud hum in my monitors that I didn't have before. I moved my system around and tried to plug my Tannoy Reaveals back in and now they have this really annoying hum. Did I do something wrong?
Old 01-28-2002, 08:30 PM
da BaSsTaRd! da BaSsTaRd! is offline
Default Re: Reveals that hum
make sure EVERYTHING is grounded and if you have a cordless phone, move it to another room....
i love my apple iPhone!
Old 01-28-2002, 10:11 PM
Roy Howell Roy Howell is offline
Even fluorescent lights do it to mine. One in particular, near the pc and digi box... When it's off, there's no hum, but I can't see a thing.....(joke,joke...) But, seriously, must be a grounding thing...
rh music
Old 02-07-2002, 05:39 AM
mlemos mlemos is offline
I just got a pair of Reveal's and last night I noticed a very annoying hum coming only from the right monitor.
The way I hooked up the power for the Reveal's was by plugging a power-strip into one of my Rackriders that has nothing else plugged into it so that I can power off the monitors before any of my other gear(without having to power off the monitors from the switches on the back of the Reveals).
The power-strip only has the 2 power chords from the monitors plugged into it.
Is this not a good way to supply power to the monitors or can this be causing a ground loop?
Thanks,
Marc
Old 02-07-2002, 06:44 AM
Cinemafixer Cinemafixer is offline
One good way to eliminate the possibility of any AC related ground loops is to totally lift the ground on everything. Plug everything into the same power strip (distribute from the same strip to other strips). Then, from the ground lift wire on the master strip, connect a wire to the closest direct ground line. I just put in a new sub-panel in the studio, and ground for it is coming directly from outside on the grounding-post itself - Neutral from the basement panel, and all hots are from the same leg from the basement - nothing in the house shares this leg.
Old 02-07-2002, 01:50 PM
Bastiaan Bastiaan is offline
maybe this is a bit off-topic here, but after my house was hit by lightning and killed my pc, vcr, tv, answering-machine, microwave etc. i got mycelf some power-spike/rfi-filter powerstrips. They indeed work since i dont hear the fridge switch on anymore on my speakers......costed something about $25 (50 dutch guilders)
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 02-07-2002, 02:02 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Read the tech info at:
http://www.equitech.com/
They have boxes that create balanced power. It will get rid of all hums and will increase as much as 20 db in your signal to noise ratio. I think a 15 amp box is a little over $1k. Read about it.
AC power has 120V on one leg and zero on the other. The ground is designed to protect you from getting schocked, not to provide a ground return for equipment.
Balanced power makes 60V on each leg. It is like balanced audio with a plus, minus and ground.
Don't lift the equipment ground without some other correct ground connecting all your equipment.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 02-08-2002, 05:56 AM
Last night I noticed that both speakers are humming but only in PTLE. As soon as I close PTLE the humming stops. I thought this was normal until I started playing mp3's using MediaPlayer and there was no hum.
While playing an mp3 I cranked up the volume on the 001 and kept hitting pause and no hum what-so-ever. Doesn't this mean that it is not a grounding problem?
Does anyone know why using PTLE causes a hum but using only the WaveDriver doesn't?
Thanks,
Marc
Old 02-08-2002, 08:24 AM
Does your mp3 player use a different sound card than PT? If so, could be the PT card has a problem. You could try re-seating it.
Park
Old 02-08-2002, 08:29 AM
Hi Park, I am playing mp3's through the Digi001 hardware but not PTLE.
Digi's reveals new box namm 2010 smmsentinc Pro Tools TDM Systems (Mac) 243 01-21-2010 02:07 AM
Tannoy Reveals. Active or Passive? jpoprock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 20 11-29-2003 02:58 AM
Tannoy Reveals ajazzie Pro Tools TDM Systems (Mac) 2 11-27-2003 08:49 PM
Reveals vs Monitor 1s ear2ear 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-25-2002 07:34 AM
Tannoy Reveals wSub nutshell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-12-2002 03:28 PM
