Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Mac)
Old 03-24-2013, 02:20 PM
Dopamine Dopamine is offline
Default is the DUET 1 stable with PT10?
I am just wondering if the Duet 1 is an upgrade from the MBox3 Mini. i like the fact that it uses FW, since I already have too many USB peripherals.
Is anyone using the Duet 1 as their main interface with PT10?
I hear the Apogee drivers can be buggy, and I am hoping this is not true.
I have a new i7 Mac mini running Mountain Lion and the latest PT release.
Thanks for any feedback.
Old 03-30-2013, 12:01 AM
Southsidemusic's Avatar
Default Re: is the DUET 1 stable with PT10?
Hey Dopamine
We have a apogee duet as a interface when traveling so we can use PT10HD outside our studio for work and it works like a charm on new MBPro Quad Core 2.9 GHz august 2012. I can really recommend the duet as we can record, make beats and mix on the fly with no problems whatsoever.
We do not use it as a main interface though but you can if you want to. Great sounding interface for no money at all. We bought it here in sweden for 120 usd.
Best
Chris
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 03-30-2013, 12:09 AM
bashville bashville is offline
We used it a lot a couple months ago with the last generation of MacBook Pro before the thunderbolts. Make sure you're using the latest version of Maestro. Everything mostly fine. Sometimes we'd lose it and wasted time trying to re-select it as the interface within ProTools, only to realize that somehow the Firewire bus had "dropped" it. It's difficult to tell since it's not a drive that you can see if it's mounted. But there's a window in Maestro that shows you the available units on your system, and it would be missing. So you'd just have to unplug and replug the Firewire cable, then you'd have it again. Usually meant rebooting ProTools. That didn't happen too often, but often enough.
HD Ultimate (Native), PT2019.5, 192, 3.2 Quad MacPro 5,1, 16 Gig, Sierra
Old 04-09-2013, 12:20 PM
shultzee13 shultzee13 is offline
Plus +1 for the Duet 1 with firewire. Sounds and works GREAT!
Old 04-09-2013, 12:37 PM
<< Plus +1 for the Duet 1 with firewire. Sounds and works GREAT! >>
what were you upgrading from? and do you notice a big improvement in sound?
My PT9 is awesome/stable.. is PT10 Upgrade worth it? awritersparadise Pro Tools 10 8 10-17-2012 09:52 PM
Is PT10 stable in Lion??? VillaLobos macOS 9 07-22-2012 10:39 PM
Is there a stable PT10 with UAD2 here ? faceb Windows 9 02-09-2012 05:36 AM
PT10 more stable PT9? ... or about the same? Lucero del Alba Windows 9 02-09-2012 01:33 AM
Picture more Stable in PT10! evs Post - Surround - Video 5 11-18-2011 08:45 PM
