Old 02-01-2011, 12:14 PM
rgvinc rgvinc is offline
Default fix file association error on LaCie firewire drive
A client laCie 800 firewire drive with Pro Tools sessions has lost file association to all audio as well as Pro Tools session files. They were created on a MAC and an older version of Pro Tools and cannot be opened through Pro Tools without an error. Even with “show extentions” on, no extensions are listed and the files show as Unix-based.
Changing the extension changes the file icon but will not open the files: example, changing the extension on a WAV file allows the icon to change but errors upon launching in Quicktime or any other audio program.
- Is there a UNIX command to change the file type?
- Did the files get corrupted, however the size seems right
- How can I verify that the files are still intact
Old 02-01-2011, 12:21 PM
plastikman plastikman is offline
Default Re: fix file association error on LaCie firewire drive
What was the format of the audio originally? wav? sd2? (you had mentioned they came from older version of PT) If it was sd2 and the files were copied to a FAT32 format drive, the resource forks have been stripped.
Old 02-03-2011, 11:25 AM
What I can gather from the owner, is that the files are probably sd2 files. Do you know a way of fixing the resource forks or - anyway of converting the audio files "as is" to a WAV format?
Old 02-06-2011, 01:05 PM
I don't know of a way yet, but I am currently trying to resolve the same issue with an old session. If I come up with anything useful, I will post my findings.
Is the mentioned LaCie drive where the files originated or had they been copied there from another drive?
Old 02-11-2011, 03:48 AM
Sorry for the delay in my response: but yes, the LaCie drive is where the files were originaly created. A later session on this same drive (the client indicated they had been created in PT5 but later worked on and saved in PT6) were able to be read by my PT9.
I haven't gotten any further either...
File association cpnraisnuts 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-20-2005 11:41 AM
File Gymnastics...PT and Powerbook w. Lacie drive Dan M. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-23-2005 09:08 PM
LaCie Firewire Drive Set Up ACEtone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-26-2003 12:12 AM
DAE error -9060 & -9073 "disk frag or too slow" with new LaCie FireWire Drive! mikerica101996 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-19-2003 08:56 AM
Why is my LaCie external 80 gig, 7200 rpm firewire hard drive an invalid drive to be Fucius General Discussion 4 03-19-2002 11:26 PM
