Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 02-22-2001, 12:08 AM
robinhow robinhow is offline
Default 8 channel digital io Digi Interface would be nice!
Hi!
I want to get more digital I/O in my mixplus systems but the only option is the 888 interface. I'd be paying a lot of money for A-D's and D-A's that I'd never use on it.
Why don't digi make an inexpensive spdif/aes 1u interface for inserting outboard digital effects gear? It's got to be easy from a hardware point of view and would make expanding the digital i/o less of a new mortgage job.
Robin
Old 02-22-2001, 01:34 AM
stevegalante stevegalante is offline
Default Re: 8 channel digital io Digi Interface would be nice!
All Digi community is asking the same since a long time Robin ! For the moment use an 888/16 which passes 24bit digital signal.
www.downinhollywood.com
http://www.stevegalante.com
System details :
ProTools Native card, Ultimate 2019.5, MacPro 5,1 12 Core 3.33GHz, 64Gb RAM, Mojave 10.14.4, Lynx Aurora(n), Raven MTi
Old 02-22-2001, 02:09 AM
Thanks, Steve - is 888/16 ok with MixPlus?
Alternatively is there an external box that receives/sends 4 x spdifs and can send/receive the same via ADAT digital pipe? That way the ADAT bridge could maybe be used?
Bruce - can you comment?
Robin
Old 02-22-2001, 04:32 AM
Yes, the 888/16 is fine; you will find many threads about alternative solutions using ADAT bridge and the like, but I found the most cost-effective solution is to buy (eventually multiple) 888/16.
System details :
cheapest USB or Firewire 2 channel DIGITAL IN interface for PT10? MixerGuy macOS 7 07-23-2012 09:09 AM
Multi Channel Digital Interface stickleback General Discussion 5 07-04-2012 09:23 PM
Multi Channel Digital Interface stickleback 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-03-2012 07:21 PM
Digi 96 i/0 with digital distortion on 1 channel T_S_Harris Pro Tools TDM Systems (Mac) 0 03-31-2011 03:50 PM
is there a digital only i/o interface compatable with digi interface connections? Felix Tips & Tricks 2 10-22-2001 10:50 PM
