Old 07-03-2008, 12:13 AM
MixerGuy MixerGuy is offline
Default monitor 5.0 on a 5.1 SMPTE monitor controller?
Here is a good one for you all….
i am mixing in surround (5.0) at a pals music studio
His setup from ProTools analog out to the monitor controller…. is the SMPTE standard
L
R
C
LFE
Ls
Rs
I want to mix (and monitor) in 5.0 there, and so not use a .1 channel at all.
I dont want to re-wire his studio at all….. as he also works on his composing rig there, using a complete separate system. (so I can’t change the layout of the wiring of his studio)
so - how can I easily create (and move around) the order of a ProTools 5.0 monitor path (outputs in ProTools) to listen to 5.0 - while adhering to the way his room is wired (SMPTE L/R/C/LFE/Ls/Rs)
Thanks!
Old 07-03-2008, 05:54 AM
Chief Technician's Avatar
Default Re: monitor 5.0 on a 5.1 SMPTE monitor controller?
Create a 5.1 monitoring path in the output tab of the I/O setup window. Within that path, move your outputs around so they are arranged per the SMPTE standard (L/R/C/LFE/Ls/Rs). If you want to monitor 5.0, your have two choices.
1. Don't route anything to the LFE channel in your mix.
2. Create a 5.0 subpath from the 5.1 monitoring path, and use the subpath as your output.
Can Studio Monitor Express & Transport act as digital monitor controller? briancares Artist Series 1 02-04-2014 05:23 AM
5.1 Monitor Controller BroomPole Post - Surround - Video 6 04-09-2009 02:23 PM
Monitor Controller? macr0w General Discussion 3 09-14-2006 03:07 PM
5.1 Monitor Controller Suggestions? spicyitaliano Post - Surround - Video 4 06-15-2006 10:33 PM
stereo monitor controller Richard Conrad Pro Tools TDM Systems (Mac) 10 08-07-2005 08:42 PM
