Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 04-22-2005, 02:55 AM
ho-fi ho-fi is offline
Default DAE Error -9131 on (LaCie) Firewire Drives
I've had the problem that a Session, opening on a FW-Drive (LaCie Porschedesign 250GB) resulted in DAE Error -9131. The Solution was to boot the mac without the FW-Drive connected, then open the disk-utility and connect the drive. then formatting.
i hope this helps somebody!
cheers
ho-fi
Old 04-27-2005, 01:47 AM
eyevee99 eyevee99 is offline
Default Re: DAE Error -9131 on (LaCie) Firewire Drives
I'm getting this error with a drive freshly formatted (and with all my sessions copied over to it).
It was working with Journaled HFS+ formatted in Disk Utility, but I needed a FAT32 partition for PC compatibility. So I created a Journaled HFS+ and FAT32 partition in terminal using diskutil:
diskutil partitionDisk /dev/disk1 2 MBRFormat JournaledHFS+ Mac 45G MS-DOS Win 20G
This command creates a Journaled HFS+ partition and an MS-DOS partition to fill the remainder of the disk. Now when I try to play I get the "DAE error -9131".
Any thoughts on this? Is it posisble to get the dual partitions working correctly so ProTools can flag the Journaled HFS+ partition as a recording and playback audio volume.
Cheers
D2 LACIE 2T HD DAE error 9131 Sam Yin Storage Subsystems 1 02-02-2010 01:41 PM
9131 Error, Lacie Triple interface FW 800 Sevitzky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-24-2008 05:01 AM
LaCie Porsche Drive Creating a -9131 Error fndmntl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-27-2006 08:25 PM
9131 error using Lacie external Firewire.NEED HELP iantracks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-23-2005 02:07 PM
LaCie firewire drives... gtrguy4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-24-2003 01:57 PM
