Old 06-11-2004, 07:26 PM
RomanVail RomanVail is offline
Default FILM:PRO-TOOLS:SYNC What equipment should I get?
I have the 002 Rack a miniDV cam, a keyboard...etc.
I read some books on ediitng and syncign audio for video and there seem to be sync issues.
If I am going to be using Final Cut Pro 4.5 and Pro-Tools LE 6.4 --with smpte and all that... what else may I need. I dont have a big budget and neeed some work-around solution a "ghetto" way.
I imagine I'd need a DAT recorder, perhaps portable?
Also some syncing device?
Also, what is a device with which I coudl change the sampel rate to account for drop-frame stuff?
I really need some help.
Thanks from NYC.
-Roman
--Roman Vail
Old 06-12-2004, 01:26 PM
Thresholdproductions Thresholdproductions is offline
Default Re: FILM:PRO-TOOLS:SYNC What equipment should I get?
You would need first off the ability to run SMPTE Timecode in protools or another DAW. Thus you would need the DV tool kit or a TDM setup. You would also need a synchroniser such as a Midi Timepiece by MUTU. That would get you up and running and would cost under $2000. You can find useed Midi timepieces on ebay...get the usb one.
Hope that helps.
J
Old 06-14-2004, 09:50 AM
luis mendez luis mendez is offline
the point here is ...Whats your final target ? its commercial?
If you hav a Final Cut 4 and PT. 6 on any version maybe only you need a
good video equipment for final pourpouses like a DVD RW on your machine ,
Betacam SP or a SuperVHS Hi Fi
w/Pt 6.1 on OSx you will import your dv video to session and sync and work fine.
But if you need work outdoors first you need a portable Dat w/ a decent mic like a
Akg 440 or Shure VP 88
To sync w/ other machines the best and unexpenssive its a Motu Micro Express USB Box,
its a midi port an sync device
Luis Mendez
CyberAudio s.a
San Jose Costa Rica
Sync-offset issues when recording with external equipment izthewiz macOS 3 03-05-2013 11:07 AM
Equipment/software needed for recording film? LaForestPoetry18 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 05-17-2007 12:00 AM
Equipment software for film... LaForestPoetry18 Post - Surround - Video 6 05-15-2007 07:51 AM
Equipment/software needed for recording film? LaForestPoetry18 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-14-2007 05:27 PM
Video Sync Equipment KirinBenjamin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 02-04-2003 08:43 AM
