Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Mac)
Old 04-07-2013, 04:49 PM
yohi64 yohi64 is offline
Default Input Question Mbox Pro
Hi all,
I'm new to the forum so I'm hoping this question doesn't seem too much of a newbie prob.
Anyway, I'd like to know if it's possible to run a mic into an outboard preamp and route it through any of the TRS inputs?
I'm trying to get past the 4 analog input limit if I can.
Old 04-07-2013, 09:04 PM
Default Re: Input Question Mbox Pro
This is not really going to get you to where you want. The 4 line inputs are the same as the 4 mic inputs(you choose mic or line for inputs 1 thru 4). So you can use external preamps, but they will go in via 1 thru 4(no gain in input preamps). You can get to 6 inputs by using a dual channel preamp with SPDIF(like the DBX-386, API A2D or ART Digital MPA). The final 2 inputs are on analog RCA at -10(designed for consumer electronics, not external preamps). If you want 8 mic preamps, I would look at Focusrite Pro40 or LS56.
Old 04-08-2013, 06:49 AM
KineticSound KineticSound is offline
^ +1 on the above. I do the same thing as albee is describing... 4 mic's running into my Avid unit, then two mic's going into an A.R.T. DPS-II mic preamp which connects to the Avid via S/PDIF.
The S/PDIF inputs are automatically routed to channels 5/6 in the Avid control panel, so you can run 6 input channels simultaneously.
If you have an outboard mic preamp that you like, you can also look for a quality converter unit such as an M-Audio Flying Calf, which takes any TRS analog signal and converts to S/PDIF at 24-bit & 44.1/48k.
Old 04-08-2013, 06:52 AM
Thanks to both responders.
I'll be looking for the hardware you've mentioned.
Mbox Mini Input Output Question stephnewbie macOS 4 11-29-2012 07:29 AM
Question about the Mbox pro 3's Aux input 5/6 jackroylee macOS 3 11-07-2012 07:14 AM
Question about the S/PDIF input on the MBox 2 jonathanvaas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-09-2006 11:31 PM
Mbox USB input question imnotwillie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-23-2004 02:51 PM
Mbox input help/question Esmeraldo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-19-2003 01:18 PM
