Cannot change clock source
Pro Tools 8.0.5 Digi 002 Rack Win 7 I am trying to hook up a Boss DR-880 via SP/DIF. I get a signal, but it's full of those familiar crackling sounds and there is too much latency delay. When I go into Setup > Hardware and attempt to change the Clock Source to SP/DIF it just pops back to Internal. Anyone know why it's not letting me change it? |
Re: Cannot change clock source
Is Windows using the 002 as its default playback device? If so, change that so Windows uses the on-board sound card.
Here's what that looks like right now:
Okay, What kind of digital output is on the Boss, lightpipe or RCA? If its RCA, change the Optical Format(in Setup>Hardware) to ADAT, which should(might) allow the RCA SPDIF to work(shooting in the dark since I don't know how things are connected). Assuming the 002 is fully working(not a sure thing due to the old "power harness" issue), the biggest reason I know for clock source defaulting back to Internal is because the connection sees no clock. Reasons for this:
1-Roland is not outputting signal on its digital output(is there a setting in the Roland that needs to change?) 2-the cable is bad or not seated(the plastic optical connectors are pretty crappy) 3-the signal from the Roland is at a different sample rate than the session. Hope something here helps. I clocked my 002 via ADAT(lightpipe) for years with several 8-channel outboard preamps(Presonus D8, Firestudio and Focusrite ISA-428 with digital option card)
Problem detected with audio clock. Check your clock source and sample rate. | sleeptalken | Windows | 7 | 08-10-2021 01:17 PM |
Cannot change clock source | Clockwork12782 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 08-17-2017 01:06 PM |
Problem detected with audio clock. Check your clock source and sample rate. | teleguy2 | Windows | 6 | 06-26-2015 01:47 PM |
Problem detected with audio clock. Check that your clock source and sample rate are c | Solow1nonly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-06-2011 08:22 PM |
"Problem detected with audio clock. Check that your clock source and sample......... | ASD15 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 03-26-2010 03:40 PM |
