  #191
Old 11-24-2017, 05:26 AM
Stephen Bond's Avatar
Default Re: Gui lag 12.8.2
I just booted from an old external drive with PT 10 installed and ran up a vintage Session. Ran real snappy and didn't take long to load at all, even considering I was running the OS and PT from the external 2.5" HDD
Makes you wonder why PT 12 is so slow all round?
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
  #192
Old 11-24-2017, 04:17 PM
zion zion is offline
Although I'm not experiencing video issues as severe as some others, I do see weird plugin mirror like images when changing the sizes. I also noticed weird double midi notes behind clips. Even if I move the clips they are still there. I also notice when I look at it in the midi event list the double midi notes are there as well. These where projects done in 12.5.2. I rolled back to 12.8.1 and when loading the exact same project the problems are gone. Some bugs have definitely crept there way into 12.8.2. Hopefully they will straighten them out quickly on the next release with-out adding more bugs. For now, its back to 12.8.1. (edit) I also noticed the CPU usage is lower with the same Project in 12.8.1 and it seems more stable.
  #193
Old 11-26-2017, 07:14 PM
PowerofEight PowerofEight is offline
I've had the MIDI note duplication issue as well. No matter how many times I delete the clip the notes still remain.
  #194
Old 11-26-2017, 08:06 PM
Are you on 12.8.2 or 12.8.1? HD or Native?
  #195
Old 11-27-2017, 07:55 AM
blemished blemished is offline
Having no problem with Edit Window, but Mix Window scrolling is very sluggish. And much as I enjoy seeing the chords appear when playing, PT overall definitely seems less snappy and - I think is making my system feel more sluggish.
This is with MacPro (mid 2012) with 10.12.3 and 32GB memory. Am not best pleased to see that Avid dropping support for older Mac Pros given the absence of a serious current Mac alternative for now. Have just resubscribed but reasons for doing so are starting to ebb - marginal improvements, poorer performance, dropped support for standard systems...
Thanks to those who explained how to roll back to 18.1 - about to do so now as previous attempts failed.
  #196
Old 11-29-2017, 03:58 AM
Uli Auer Uli Auer is offline
Same here after updating to 12.8.2 !!!
Unbearable loss of speed in general....I'm working with a pretty huge template using self-defined "fader packs" of 16 channels hiding/showing those tracks I want to access by recalling locators.....now after the update it takes sth around 4 seconds (!) to recall a locator....!!!
Avid: PLEASE DO YOUR HOMEWORK !!!
Those GUI lags are apparent for YEARS now....!
  #197
Old 11-29-2017, 04:34 AM
Same here. Dreadful.
  #198
Old 11-29-2017, 05:02 AM
Originally Posted by Dudiester View Post
In both cases I simply went back and installed 12.8.1 and both systems are running amazing again.
Anyone know if I went back to 12.8.1 would I need to re-install the 12.8.1 driver as well?
  #199
Drew Mazurek's Avatar
The HD Driver?
no.
www.drewmazurek.com
  #200
Old 11-29-2017, 05:14 AM
Update for further information (though expanding a little into off-topic-land):
Since updating EVERYTHING seems to be very slow (the whole "UI" and not only the GUI if that makes sense) - not just scrolling....that also includes loading/closing sessions (endless waiting times). While recalling the locators as described above sometimes I even get a process bar for a while that says sth like "re-ordering track layout" - which I've never seen before...
Also many unexpected quits of PT in general while closing a session....and sometimes when inserting or removing plugins that change the mono/stereo mode of the particular track.....
