Old 05-01-2012, 11:52 AM
Zacsyd Zacsyd is offline
Default Copy/Paste plugins settings between different plugins?
I just wonder. Is there any way, that i can lets say, copy all parameters of for example pro tools stock 7 band EQ. And paste it in to another EQ? (waves, sonnox, etc)
I tried and i tried but can't get it to work. I can't really see the problem either. I mean, of course the parameters are gonna missmatch sometimes, but then the paste should just ignore parameters that aren't there??
Thanks
Old 05-01-2012, 05:07 PM
Meads's Avatar
Meads Meads is offline
Default Re: Copy/Paste plugins settings between different plugins?
How on earth should this work?
Ever tried to copy a a text document into a calculator? That's basically, what you're trying to accomplish here.
iMac Pro
- MacOS 10.14.5
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24
Old 05-01-2012, 07:01 PM
Yeah, not going to work. Solution: open both and just adjust the 2nd to match the first. Having said this, they may not sound the same(any more than 2 brands of hardware EQ would).
Old 05-01-2012, 09:42 PM
Oh please it isn't really the same thing. EQ is an EQ is an EQ. You can't really compare different EQs with text documents and calculators.
But just to answer your question, no i have never tried it. But i can't really see a big problem there either.
If i write a bunch of numbers in a text document on my computer, and copy them. It shouldn't be a big problem pasting the numbers in a software calculator. that's what i think at least....
Old 05-01-2012, 09:48 PM
Meads's Avatar
I'm not a coder, but from what I know about programming, I'm pretty sure an EQ is not an EQ is not an EQ from a software engineer's POV. At least not in the manner, that you could copy parameters from one to the other, because source codes aren't conform.
iMac Pro
- MacOS 10.14.5
- C|24
Old 05-01-2012, 10:02 PM
How is "an EQ an EQ" from anybody's perspective let alone a software developer's? What parameters that affect say a five band EQ would you apply to a three band EQ and how exactly do you decide what parameters to ignore when things don't match up. Let alone worrying about mixing multi-band EQs and parametric EQs?
This is simply is not done because the idea is impossible/makes no sense.
Darryl
Old 05-02-2012, 02:32 AM
Felix Rost Felix Rost is offline
you can't copy all at once, but copy/paste special single parameter's automation. then see how it translates
Old 05-02-2012, 03:31 AM
ejwells's Avatar
ejwells ejwells is offline
How about a simple answer to your question?:
No.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack |
Old 05-02-2012, 03:33 AM
No.
how about copy special/ all automation ?
PTHDn 2019.6 (OSX10.14.4), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 05-02-2012, 07:26 AM
WernerF WernerF is offline
If you want it to sound the same why not use the same kind of EQ on the tracks that you want to match. All you have to do then is option drag the plugin over to the other one.
Copying from one brand of EQ to the other is just not gonna work no matter how much you want it to. Too many things are different from one to the next.
PT10+10.7.2: COPY+PASTE automation settings "not compatible ?" bennym macOS 6 04-04-2012 04:37 PM
Copy works paste doesnt paste??? SoMedia Pro Tools M-Powered (Win) 12 01-04-2011 01:19 PM
Shuffle doesn't shift volumes - copy & paste doesn't copy automation marcnyc Pro Tools TDM Systems (Mac) 2 03-12-2010 12:46 AM
Copy plugins from windows mfefc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-11-2008 10:05 AM
how do i copy plugins from one session to another? maskedman72 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 04-05-2004 12:58 PM
