Old 11-08-2010, 01:54 AM
mattyd27 mattyd27 is offline
Thumbs down Recording early issue in 8.04cs2
Hi all
Here is part of the release notes for 8.04cs2:
On Windows, Pro Tools LE was recording audio to the timeline early by approximately twice the H/W buffer size. (PTSW-130757)
* Audio was recorded early depending on the hardware buffer size selected. This problem was specific to Pro Tools LE 8.0.4 on Windows. Fixed in the included Pro Tools LE Avid Audio Drivers installer.
I have XP and 8.04cs2.
I did a session yesterday recording keyboards and the issue was most certainly still there.
Had a H/W Buffer size of 1024 samples.
After the keys had been tracked I had to push it back by 2048 samples to make it in time.
It was not a player issue as I then tested it with a microphone, singing along to a song I know well. Same issue.
I'm currently using a:
2.8GHz AMD Athlon 64 Dual Core
4GB DDR2 RAM
Mbox 2 Mini
Running Windows XP Professional.
My click track also just decided to stop working, then start working using a different tempo, then stop working again. It was like that for about a week and thankfully rectified itself, without me doing anything, just in time for the session.
Should I try a fresh install? Or maybe just a fresh install of the drivers? How would I do just the drivers?
Any help would be appreciated.
This is a serious issue and I'm actually contemplating going back to 7.4 as I had ZERO issues with that version.
Thanks.
Old 11-08-2010, 06:30 AM
MikeLip MikeLip is offline
Default Re: Recording early issue in 8.04cs2
If you're still getting early placement, then I would guess you still have an earlier buggy driver installed. Check driver version in Device Manager.
Its a bit fiddly to get the right driver working. You could try grabbing the driver being pushed as part of the PT9 release. I think its the latest and maybe work with 8.04cs2.
Mike.
This might qualify for "the best worded, but most idiotic thing I've ever heard said" award.-ejwells
Avid Pro Tools|HD Native 9.0.3. Win7x64Sp1. i7-930 X58A-UD3R. Acronis backup. Black Viper optimized.
Google the DUC
Search Avid
Old 11-08-2010, 07:10 AM
Thanks a lot.
I will do that and report back.
Audio recording quieter since 8.04cs2 MikeLip Windows 1 01-20-2011 06:48 PM
DTS Confirm/Deny 8.04cs2 timeline recording late? MikeLip 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-20-2010 06:20 AM
Audio Recording Early macrae11 Pro Tools M-Powered (Mac) 5 04-27-2010 10:38 AM
Anyone having the excessive heat issue with early 2009 Nehalam Mac Pros? MDH25 Pro Tools TDM Systems (Mac) 0 02-04-2010 03:27 PM
midi recording early?? mrdale MIDI 3 11-21-2006 08:36 AM
