Old 03-25-2018, 03:51 PM
sonicapg sonicapg is offline
Default Digi 002 console ADAT problem
Hi
I am trying to connect Behringer ADA8000 to ADAT input as a Master but ProTools does not allows me to select ADAT as clock source.
Things I have tried so far are :
1. made sure ADA8000 is master @44.1 and 48khz *failed
2.tried another optical cable.
3.Tried another unit's ADAT out *Terratec MIC 100 ,*failed
PT 8.05 WINDOWS 8 64bit ,16gb ram
Any ideas?
Just used ADA8000 as a Master to sync Terratec and Terratec synced fine. *there is a led indicator on it.
Old 03-25-2018, 06:48 PM
Default Re: Digi 002 console ADAT problem
Some things to check:
In PT, check the hardware setup and make sure Optical=ADAT(if optical=SPDIF, that could be the trouble).
Try using 2 lightpipe "cables" 002 OUT to ada8000 IN, and ada8000 OUT to 002 IN. Set the ada8000 to use external sync(this lets the 002 be the master clock).
Old 03-26-2018, 01:42 AM
Thanks Dave
I'll try that
BTW when launched 002's diagnostics ,tested ADATbut got no audio
I started thinking if there might be wrong with hardware....then again its OPTICAL connector ,it self seal the socket ....I don't know....
Old 03-26-2018, 03:47 AM
Finally ,mystery solved !!!!!
the freaking ADAT PLUG should be pushed to click in the ADAT socket !!!!!
Now it works......
Thanks Dave
Old 03-26-2018, 08:03 PM
Good detective work! Those plastic plugs are pretty crappy, to say the least
Digi 002 console LCD problem eyal-gr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-28-2011 12:18 AM
digi 002 console problem yasinby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-29-2008 08:41 AM
Digi 002 Console problem rowdy11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-13-2006 05:21 PM
DIGI 002 Console problem rowdy11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-05-2006 11:01 AM
Problem: NEED NEW Digi Console [email protected] Pro Tools TDM Systems (Mac) 2 05-30-2001 11:17 AM
