Problems with Pro Tools/ Focusrite 6i6
Hey you all!
This is my first post here after reading some similar threads and trying the recommendations without luck. I got Pro-Tools 12 last week and installed it. Now after being done with the configurations and wanting to do some test projects, whenever I hit the space bar, the play icon blinks a couple of times, and nothing happens. I tried: -unsintalling and installing again, with administrator rights, the drivers of the focusrite (Mixcontrol) -changing the buffersize -changing the sample rate -restarting the computer -uninstalling and re-installing Protools Do you guys have any suggestions? I'm gonna test an M-Box and an RME device this week to see if the problems is from the Focusrite. But that's been my suspicion from the beginning. Thanks for your help! Juan |
Re: Problems with Pro Tools/ Focusrite 6i6
Oh, by the way, here's my system information:
System Details Win 7, 64 Bits // Intel Core i7-4765T // RAM 16 GB // Focusrite 6i6 // Pro Tools 12.6 Update: I tried the MBox and it works fine. Has any of the Scarlett users experienced something like that? I mean, I can't imagine that Scarlett isn't compatible with pro tools. Thanks again |
See threads on disabling windows sounds , otherwise must set sample rate of Windows sounds to same as mixcontrol, same as pts session
Sent from my iPhone using Tapatalk |
Since you are both new to the forum, please review the Help us Help You thread, which has general optimization and troubleshooting tips, as well as how to post detailed system information. Lots of people are successfully using Scarlet series interfaces, and Focusrite has a presence on this forum, so be as detailed as you can about your setup and the issue you are having, and I'm sure we can get you going. |
I installed Pro Tools 12.6. this is my first Pro Tools version. Whenever I hit play on any project, the play button will blink a couple of times and then nothing happens. My interface is a Focusrite Scarlett 6i6. I haven't had any problems with it using other DAW (Sequoia, Ableton, Cubase) on this computer. Sample Rate is the same for playback device and DAW. what I've already tried as listed in the first post: -unsintalling and installing again, with administrator rights, the drivers of the focusrite (Mixcontrol) -changing the buffersize -changing the sample rate -restarting the computer -uninstalling and re-installing Protools SiSoftware Sandra Computer Model : HP EliteDesk 800 G1 DM 103C_53307F G=D Serial Number : MXL53***** Chassis : HP Desktop Mainboard : HP 1825 Serial Number : MXL53***** BIOS : HP L04 v02.25 07/20/2016 TPM - Trusted Platform Module : 1.02, IFX Intel vPro : 9.01.20.1035 Total Memory : 16GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i7-4765T CPU @ 2.00GHz (4C 8T 3GHz, 3GHz IMC, 4x 256kB L2, 8MB L3) Socket/Slot : FC LGA1150 Chipset Memory Controller : HP Core (Haswell) DRAM Controller 100MHz, 2x 8GB DIMM DDR3 1.6GHz 128-bit, Integrated Graphics Memory Module(s) Memory Module : Crucial CT102464BF160BM16 8GB DDR3 SO-DIMM PC3-12800SO DDR3-1600 (11-11-11-29 5-40-13-6) Memory Module : Crucial CT102464BF160BM16 8GB DDR3 SO-DIMM PC3-12800SO DDR3-1600 (11-11-11-29 5-40-13-6) Video System Monitor/Panel : Hewlett Packard HP 27es (1920x1080, 27.2") Monitor/Panel : Hewlett Packard HP 27es (1920x1080, 27.2") Monitor/Panel : Hewlett Packard HP 23xi (1920x1080, 23.1") Video Adapter : Intel(R) HD Graphics 4600 (20CU 160SP SM5.0 600MHz/1.2GHz, 512kB L2, 192MB DDR3 1.6GHz 128-bit, Integrated Graphics) Video Adapter : Intel(R) HD Graphics 4600 (20CU 160SP SM5.0 600MHz/1.2GHz, 512kB L2, 192MB DDR3 1.6GHz 128-bit, Integrated Graphics) Graphics Processor OpenCL GP Processor : Intel(R) HD Graphics 4600 (160SP 20C 600MHz/1.2GHz, 256kB L2, 1.3GB DDR3 1.6GHz 128-bit, Integrated Graphics) Compute Shader Processor : Intel(R) HD Graphics 4600 (160SP 20C 600MHz/1.2GHz, 512kB L2, 192MB DDR3 1.6GHz 128-bit, Integrated Graphics) OpenGL Processor : Intel(R) HD Graphics 4600 (160SP 20C 600MHz/1.2GHz, 512kB L2, 128MB DDR3 1.6GHz 128-bit, Integrated Graphics) OpenGL Processor : Intel(R) HD Graphics 4600 (160SP 20C 600MHz/1.2GHz, 512kB L2, 128MB DDR3 1.6GHz 128-bit, Integrated Graphics) Storage Devices Crucial CT1000BX100SSD1 (1TB, SATA600, SSD) : 932GB (C:) (D:) (E:) Logical Storage Devices SYSTEM : 1GB (NTFS, 4kB) @ Crucial CT1000BX100SSD1 (1TB, SATA600, SSD) Windows (C:) : 915GB (NTFS, 4kB) @ Crucial CT1000BX100SSD1 (1TB, SATA600, SSD) HP_RECOVERY (D:) : 15GB (NTFS, 4kB) @ Crucial CT1000BX100SSD1 (1TB, SATA600, SSD) HP_TOOLS (E:) : 103MB (FAT32, 1kB) @ Crucial CT1000BX100SSD1 (1TB, SATA600, SSD) Peripherals LPC Hub Controller 1 : HP Lynx Point LPC Controller Audio Device : HP Core (Haswell) HD Audio Controller Audio Codec : Intel 2807 Audio Device : HP Lynx Point HD Audio Controller Audio Codec : Realtek Semi High Definition Audio Serial Port(s) : 1 Disk Controller : HP Lynx Point 6-Port SATA AHCI Controller USB Controller 1 : HP Lynx Point USB xHCI Host Controller USB Controller 2 : HP Lynx Point USB Enhanced Host Controller #2 USB Controller 3 : HP Lynx Point USB Enhanced Host Controller #1 SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP ePrint (600x600, Parallel, Colour) Printer : Foxit PhantomPDF Printer Driver (300x300, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Intel(R) Ethernet Connection I217-LM (Ethernet, 1Gbps) Wireless Adapter : Intel(R) Dual Band Wireless-N 7260 (802.11n (HT), AES-CCMP, 300Mbps) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 |
Already tried those steps. Doens't change a thing. |
Problems with new Pro-Tools 12 and Focusrite 6i6 | The_Juan | Windows | 0 | 10-31-2016 03:58 AM |
Problems with Pro Tools 9 and Focusrite Saffire | SheikYerboti | Third Party Interfaces | 12 | 08-31-2014 09:54 AM |
Pro Tools 9 and Focusrite Scarlett 8i6 - Problems! | willyguitar | Pro Tools 9 | 0 | 11-28-2012 03:57 AM |
Pro Tools 9 with focusrite liquid saffire 56 problems | johanonsydow | Pro Tools 9 | 24 | 02-18-2011 06:21 AM |
Problems with Focusrite D2 | Robert U | Pro Tools TDM Systems (Mac) | 1 | 05-18-2000 11:17 PM |
