Old 01-15-2008, 10:35 AM
shultzee13 shultzee13 is offline
Default Converting from 24 bit to 16
I Have recorded a session in 24 bit but now that I am going out to a CD burner how do I convert to 16 bit like the manual says I should? Go to preferences? Has anyone stayed in 24 bit and gotten some weird popping sounds on their mastered recorded CD? I am coming out of the Firewire 410 channel 1 & 2 for a stereo mixdown.
Thanks guys.
Pro Tools 11.3.1 & 10.3.8
Interface - Focusrite Clarett Pre2/Clarett Octopre
Computer - Mac Mini 2.5 GHz Intel Core i5, 16GB
OS - Yosemite
Monitors - Yamaha HS8
Old 01-15-2008, 11:29 AM
DigiTechSupt's Avatar
Default Re: Converting from 24 bit to 16
Typically you would just bounce to disk and, in the BTD options, choose 16 bit for the output bit depth.
Avid Audio Tech Support
Support FAQ
Old 01-16-2008, 01:31 PM
Then why would you ever want to record in 24 bit if it is going to end up in 16 bit on a CD? Just wondering.
OS - Yosemite
Old 01-16-2008, 02:02 PM
spkguitar's Avatar
Because of the headroom 24bit will give you when recording/mixing.
Old 01-23-2008, 04:33 PM
But it will end up in 16 bit anyway right? On a CD.
Maybe I am missing something here.
OS - Yosemite
Old 01-23-2008, 06:43 PM
spkguitar's Avatar
Recordings at 16-bit resolution have a theoretical dynamic range of 98dB, whereas 24-bit have a dynamic range of 120 dB. The significance is that the greater your dynamic range is, the lower the noise floor is and the higher your maximums are.
That's a track-by-track, significant difference. So even if your target medium is 16-bit(CD) for your final two-track stereo mix, your overall audio is going to sound better if it is recorded at 24-bit.
Old 01-24-2008, 05:38 AM
tash tash is offline
Maybe you need to put dither plug-in when you get 16 bit files from 24 bit ones? That could be the cause of funny noise.
It is sort of popular practice to record everything @24 bit 44.1k and lowered the resolution at the end.
Converting to MP3 keytone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 02-24-2009 06:54 PM
mp3 converting HELP?!?! steve.05251 Pro Tools M-Powered (Win) 0 01-28-2009 04:58 PM
Converting from pc to mac! i need some help mr razor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-16-2008 03:09 AM
Converting 24 bit to 16 mblack Pro Tools TDM Systems (Mac) 14 04-02-2005 06:55 PM
converting from 48K with PT Grillo Pro Tools TDM Systems (Mac) 4 05-16-2000 04:53 PM
