Missing stock plugins
I've noticed that some stock plugins are suddenly missing from the menu. At the very least this includes Trim and the the Tuner plugin (I can't remember the name exactly) that you can use to tune an instrument (not autotune, but an actual tuner).
I can actually see Trim.aaxplugin file sitting under /Library/Application Support/Avid/Audio/Plug-Ins but it's not actually listed in Protools for some reason. Also, I have an existing instance of Trim in a couple of tracks. They are working, and I can make copies of them. It's like PT just lost the link to them. To troubleshoot, I tried closing the program, deleting InstalledAAXPlugins, and using the PT Prefs tool to wipe out basically all prefs, cache, databases, etc. I also rebooted. How can I get the stock plug-ins back into Pro Tools? |
Re: Missing stock plugins
Well, I found Trim under the Multi-Mono plugins. Is it supposed to also be under multichannel plugins?
I still haven't found the stock tuner. Though it looks like I have a tuner via Waves GTR which might work for now. I'd still like to figure out where my stock plugins are. |
Glad you found Trim. It is a mono plug-in and is also available in multi-mono format (with channels linked by default).
InTune is only available on mono tracks, so make sure you are checking the Other section of a mono Audio or Aux track's Inserts.
• linkedin •
Thanks! I was able to find it. Looks like all is well.
Pro tools 12 installation missing the stock plugins | Padraig | Pro Tools 12 | 27 | 09-22-2016 06:08 AM |
Pro Tools 10 all original stock plugins missing? | mkd1973 | Windows | 4 | 09-08-2013 08:24 PM |
PT 10 Stock Plugins Missing | ukno.dino | Windows | 2 | 01-02-2012 02:52 PM |
Solution for anyone missing PT 10 stock plugins. | mkd1973 | Windows | 0 | 01-02-2012 05:51 AM |
Pro Tools 10 Stock Plugins Missing | ukno.dino | Pro Tools 10 | 0 | 12-23-2011 11:59 AM |
