Old 12-07-2009, 05:41 PM
cinetj cinetj is offline
Default Console x GUI
Being heretical out of pure ignorance... Be gentle, please.
Raised a GUI guy (which sounds corny as hell by the way...) and having litle
experience with consoles (a Control 24 is a recent acquisition in the small studio I work) I find difficult to use the console for some purposes. Dialog volume automation for example. For me it's much easier do every litle adjustement with a mouse than writing automation in real time. How wrong could I be?
Old 12-08-2009, 04:21 PM
GlennR01 GlennR01 is offline
Default Re: Console x GUI
Not wrong at all. You need to work with a mouse. It's fine. :)
Mac Pro Bloomfield Mid 2012 3.2GHz Quad Core 32GB • Mac Pro Harpertown 3.2GHz 8 Core 16GB • Mac OS 10.9.1 • PTHD 10.3.9 • PT HD 11.2.1 • PT HDX2 • PT HD7 Accel • Magma PE6R4i • 192 IO x 6 • 192 Digital IO x 2 • HD Omni IO • D-Control 32 Fader • UAD2 Octo Ultimate
Old 12-09-2009, 02:43 PM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
I of course disagree wholeheartedly with Sir Glenn ...
Cinetj,
I suppose you are talking about 'fine tuning' volume automation correct ? As in making a selection and then trimming things down ?
Or are you saying you find it hard to use the faders in general to write automation ... as in following along / riding the faders during playback ?
Just curious ... and of course also hoping to help to change your mind. You sound like you do not have a lot of 'fader milage' under your belt but nothing wrong with that and I can certainly understand that burned in habits can be hard to break. The idea of these controllers is to improve and make your workflow easier ... not to be a hassle.
I think a lot of it may lie in little things that help fader automation in countless ways. A proper understanding of things like automatch / join / autojoin for example ... things that you are not likely to use when mixing with a mouse but life essential when mixing on these controllers.
Or the actual automation modes .... again a BIG difference to what you would typically use when mixing with the mouse. LATCH BABY ... I'm willing to bet that you are not used to using that right ? Well .... you should investigate what it can do for you in combination with the couple of things I mentioned above.
There's TONS more but probably irrelevant at this point for you. As with all things ... it will ask a certain amount of commitment at first but I think I can guarantee you that if you are willing to put in some commitment and explore what it CAN do for you to improve your workflow ... you will NEVER go back to adjusting things like volume automation with the mouse. Well ... not for 99.999 % of what you have to do with it anyhow.
Chris
Chris Lambrechts
Applications Specialist- Live Sound
Old 12-11-2009, 08:36 AM
macaholic macaholic is offline
I have to agree with Chris on this one as well...
I have only had my D-Command about a year and a half and cannot imagine going back to doing Dialogue rides with a mouse. After using the ICON, I found myself using all of PT Auto modes (except for Write ;-), and feel like it makes my workflow faster, simply because you are actually "mixing" in realtime, rather than adjusting levels with a mouse.
Of course I'm in a post environment, so cannot comment as to the music side of things, but won over another one of the guys I work with who is stractly a mouse guy too, when he saw I was able to tweak multiple things at once (volume, sends, and pan) not to mention the ability to be able to actually "grab" a couple knobs on the center EQ section and be able to sweep more than one thing at a time.
JC
002 console + MC Mix therecordinghouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-26-2009 04:14 PM
Console or HD? Jsswtpmp182 Pro Tools TDM Systems (Mac) 8 08-28-2007 07:02 AM
002 console & 888/24? Craig Woolard Pro Tools TDM Systems (Mac) 3 12-07-2005 01:34 PM
MMC and SSL console Jsalam112 Tips & Tricks 3 11-22-2002 04:06 PM
MTP AV console Fokke van Saane Tips & Tricks 2 09-14-2000 05:27 AM
