Calculating Waveforms and Synchronizing Folder Contents randomly
Hello,
I've searched a few threads about this, but they all seem either related to mounting/unmounting drives or improperly formatted drives on an older version of PT. System specs in signature, and the hard drive I'm running is a 4TB drive formatted MAC OS Extended (Journaled) Spotlight is enabled and nothing is in the privacy list. I've completed two whole seasons of TV shows this year on this same hard drive, and its only now (after upgrading to 12.8) that I'm getting these issues. Randomly, and I do mean randomly, it will start calculating waveforms and synchronizing Folder Contents. Because my session is an hour long dialogue editorial session, it takes sometimes 20-30 minutes to calculate all the waveforms of the assembly. Any suggestions or help would be greatly appreciated. Its happened twice today within the last few hours. I'm hoping its not starting to happen more frequently. I can't afford the downtime (audio plays ok, but video can't keep up when calculating)
MacBook Pro: Retina, 15", Mid 2014 Processor: 2.5 GHz Intel Core i7 Memory: 16GB 1600 MHz DDR3 OS: 10.12.5 PT: 12.8 HD - no interface. headphones and ilok. |
Re: Calculating Waveforms and Synchronizing Folder Contents randomly
Same issue here on our HDX systems. Huge problem with this bug.
First, easiest thing to try would be move the session to a different known good drive, unmount the drive you're currently using and see if the problem recurs.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
I've been having this issue as well. Not so much the waveforms, but the Synchronizing Folder Contents. It always bogs down my session. I'm not running a heavy session. Usually testimonials (2 dialogue tracks, music, sfx, busses, etc.). about 3 min sessions. But this happens on any session i run, even longer TV episodes.
It seems to happen every time i save my session. Weird thing is, this happens even when working locally. I'm not working off an external/server. I always start/save my session on my local machine, than transfer it to a server after completion. Running Mac trashcan, 10.11.6 (El Capitan). Pro Tools Ultimate 2018.10 Thanks! |
Ya, unfortunately the computer I have had El Capitan already installed on it. And you know how easy Apple makes it to downgrade... I usually don’t upgrade my OS since AVID is usually behind on its compatibility.
But to answer your question, yes, I am importing session data, video files, and AAFs from a shared server. If this is posing the problem, what’s your advice to fix this? Thanks in advance for the help!!! |
As to OSX you wouldn't have to downgrade but upgrade to Sierra or High Sierra. |
Cool, ya seems like that's the best way to go moving forward.
Thanks for the help/advice!! |
Catalog not calculating waveforms | idris | Post - Surround - Video | 1 | 03-01-2016 06:07 AM |
Waveforms not calculating for OMF on Xsan | NylonOxygen | Pro Tools 11 | 13 | 02-01-2016 08:43 AM |
Trashing prefs and calculating waveforms | idris | Post - Surround - Video | 0 | 03-06-2011 02:38 AM |
Is 'CALCULATING WAVEFORMS' really necessary? | Eric Seaberg | Pro Tools TDM Systems (Win) | 13 | 07-01-2009 03:14 PM |
calculating waveforms repetedly | JasonNYC | Pro Tools TDM Systems (Mac) | 4 | 09-14-2002 07:25 AM |
