Old 11-29-2017, 06:08 AM
Moviesound Moviesound is offline
Default Slaving Logic X 10.3.2 and PTHD 12.8.2 on same mac
This used to work fine with PT11 but since PT12 they no longer follow when the master is set to loop
I used to use Logic as master sending MTC to PT11. This worked perfectly, both systems would be in 'perfect' sync (the only issue would be a few milliseconds break in sound on the slave mashine at the beginning of each loop..but now
Which ever I set to be the master/slave. The slave no longer follows the masters loop range - it just carries on playing regardless.
Anyone got this working?
Old 11-29-2017, 08:04 AM
panamajack's Avatar
panamajack panamajack is offline
Default Re: Slaving Logic X 10.3.2 and PTHD 12.8.2 on same mac
Search the Avid Knowledge Base for PT co-install. On 10.8.5 (Mountain Lion), co-install with PT 10.3.6 and higher is supported up to PT 12.4. Not sure how that correlates to Logic and PT, but possibly both OS version and PT version will affect your success.
PT10.3.10HD(Tyan s2932 [8core Shanghai 2.7GHZ] 32GB,Win7 SP1); PT10HD(Tyan s2892 w/10GB, Win7 SP1);PT8HD(Dell 690 quad Xeon 3.0, 8GB, Win7,192 I/O, 96 I/O);MacBook Pro: 11R, Apogee Element 46, Focusrite 8PreX PT HD 11.3.2; Mac Pro 3.47 Hex 32GB, OSX 10.12.6/L10.4.2;L9.1.8, 2.64TB; G5 D2.3 4GB, 10.4.11/L8; 12c MP 2.66/32GB PT12.4; Structure, GigaGS3, Kontakt 5, Garratin, Sibelius 8.7+, Finale26,EMU,Vegas Pro 16-10/; RME HDSP9652,MOTU 2408 MKIII/1224/308, FX,Kurz,L5s,Strat,ASAT,JB,Zon
Old 11-29-2017, 10:53 AM
After hours trying to work this out. After various reboots PT12 is suddenly playing ball, even though it didn't before with the same settings
Frame discrepancy when slaving Pro Tools to Logic kidpolaroid Pro Tools 11 0 12-11-2016 09:39 AM
Slaving Logic X to PT10 via Network (Ethernet) DelawareAve95 Pro Tools 10 1 08-10-2015 08:58 PM
Help Slaving Logic Studio to Pro Tools Premo Pro Tools TDM Systems (Mac) 124 05-08-2014 08:35 AM
Logic 8, PTHD 7.4 & Mac OS 10.4 acmost Pro Tools TDM Systems (Mac) 2 01-05-2009 08:47 AM
Slaving Logic off Pro tools through rewire Paul Maunder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-07-2004 10:37 AM
