Re: Sidelined by CPU Problem on 32GB Mac
-6101 errors are sometimes caused by slow disk drives or overprovisioned drives where the samples live so how is all this set up?
Best Regards Christopher #thestruggleisreal ————————————— South Side Music Group WEBHOME ————————————— |
To the OP: I'd still just quickly exclude session corruption, and if still stuck I'd try removing all .aaxplugin files from the plugin folder, trashing prefs again, and doing a clean install of a newly downloaded version of Omnisphere 2 if there are still problems. If you can do a few more troubleshooting tests then are still having problems with a simple session with Omnisphere 2 I would drop that session on a file share site and you will likely find folks here who can test drive it for you. Last edited by Darryl Ramm; 07-08-2020 at 12:38 PM. |
Marsdy, yes, I was running one multitimbral instance of Omnisphere. So I experimented with your suggestion of individual instances and it seems the problem is solved. It looks like one core was in fact getting overloaded and causing the CPU error. In a fresh session and on 8 individual tracks, I ran 1 instance of Omnisphere per track without any issues. Then in addition to that, I added one more instance, this time with multitimbral tracks and by the fifth track, it shut down. So I deleted that one and kept going with individual tracks. I got up to 12 total instances of Omnisphere plus I added some other power hogs like Keyscape (2 instances), two MiniGrands, and EW Hollywood Strings. I finally got the CPU error when I added the strings. Thanks for suggesting this and to all the other responses, happy to be back up and running! |
Good to hear
Yessir, Omnisphere 2.6 and all up to date.
#16
#17
Yes, I guess I'll have to use individual tracks until I have an extra 10G's for the new Mac Pro... I thought the idea of using only one instance of these programs in a multitimbral fashion was to use less power, not more?! I was way off on that one, thanks again for your help Darryl.
#18
That synth streams from the hard drive which according to them is configurable. Get a nvme and don’t use the system drive if you happen to be using it for your sessions.
spinsong.com |
#19
It's hard to believe this plugin would cause problems with the sessions and samples being on the internal PCIe/NVMe SSD. All I would do is confirm disk cache is set to a size suitable to cache the session. But even without disk cache, this is such a light workload for a PCIe/NVMe drive. |
#20
ProTools 10.3.5 & Mac Pro 32GB | alqadhi44 | General Discussion | 1 | 06-17-2013 09:12 PM |
...and in a puff of smoke, I was sidelined. | kooz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-19-2009 08:29 PM |
