Old 02-07-2019, 05:14 PM
nicolasvr nicolasvr is offline
Default RME Totalmix loopback delay between DAWs
Hi
i'm routing PT11 to Ableton 10 through the virtual cables loopback-system Totalmix offers with the MADIface Pro i own, and back into PT to print the efx used in Live. This is my setup:
In PT:
External FX 1 send -> MADI 1/2
In TotalMIX:
MADI 1/2 (software playback)-> MADI 1/2 hardware output (loopback)
In Live:
MADI 1/2 (hardware input) -> Live efx chain -> MADI 3/4
In TotalMIX:
MADI 3/4 (software playback) -> MADI 3/4 hardware output (loopback)
In PT:
MADI 3/4 (hardware input) -> External FX 1 return
Problem is that i'm getting a 0.5sec delay between the source track in PT and it's processed return..
Anyone could help a hand with this?
Dell Inspiron 17-7778 laptop
2.6 GHz Intel Core i7-6500U
16GB RAM - Win 10 Pro
Pro Tools 2022.9
Old 02-07-2019, 07:01 PM
BScout BScout is offline
Default Re: RME Totalmix loopback delay between DAWs
RME loopback only eliminates the latency in routing. The audio card as used by both Ableton and Pro Tools still use buffers to get audio to/from the card. That isn’t eliminated; audio isn’t instantaneously in the other DAW.
Old 02-08-2019, 05:06 AM
I see.. pretty logic yes.
no other way than having to bounce the tracks from PT and importing them in Live.
Thanks for your time BScout.
Pro Tools 2022.9
Old 02-08-2019, 06:41 AM
The Weed's Avatar
The Weed The Weed is offline
Or manually shift the track(s) into position if you know the amount of latency.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 02-08-2019, 07:34 AM
Reduce your buffers as much as possible.
Key in the manual delay comp number.
In essence, treat it like any other hardware FX send
PT crashing with RME ufx totalmix kobi_dog Windows 7 04-10-2017 01:39 AM
MC Mix and Totalmix therecordinghouse Artist Series 6 04-22-2015 03:32 PM
Eucon and RME Totalmix FX anason-records Artist Series 4 01-02-2015 06:37 AM
Macbook Pro 2gb of ram with RME Totalmix? thepilgrimsdream macOS 1 06-21-2012 02:42 PM
MC Control not controlling RME totalmix johngar Artist Series 2 08-08-2011 07:13 AM
