Could not create a new document because...
Could not create a new document because Assertion in "/Volumes/Development/ws.ProTools_10.3.6/AlturaPorts/DFW/MacBuild/../View/UMenu.MacOS.mm", line 1351.
Pro Tools won't open. What can I do? Thanks.
http://GinBeck.com |
Re: Could not create a new document because...
Awesome!
Thanks, Jonathan!
Although I managed to delete those PT10 files successfully, I still get the same error message when I try to open PT11.
Where can I find PT11 files? Also, I've got 250 SSD and 8 GB RAM on my MacBook Pro and I get this, "A CPU overload error occurred. If this happens often, try increasing the "H/W Buffer Size" in the Playback Engine Dialog, or removing some plug-ins. (-6101)" and I'm running only 2 or 3 plug-ins and the buffer is already all the way up. What am I doing wrong? Thanks, Jonathan!
Hold down N while the splash screen is loading - then change ur playback engine to your interface
Fix
Splash screen?
I do agree with you on the Eleven Rack GUI!
Oh, okay! :)
Thanks!
PT 11.1.2 and 10.3.8 can't create new document | bdeivert | Pro Tools 11 | 14 | 06-24-2014 06:53 PM |
Could not create a new document...?!?!??!!! | voidmix | macOS | 7 | 02-08-2014 02:44 AM |
Could not create new document because assertion | angelstrack | Pro Tools 11 | 5 | 11-03-2013 01:08 PM |
''Could not create a new document because...'' | lanstrad | macOS | 0 | 05-05-2012 10:34 PM |
"Could not create new document because: (-51) HELP | bluesigns | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-05-2004 06:26 PM |
