Old 03-28-2019, 11:50 AM
Nick Namnone Nick Namnone is offline
Default can't get Artist Control and Mix to work at the same time-Never mind. I need a router
I did some searching but didn't see this exact problem.
Mac Pro 2013? (Trash Can) OS 10.12.6 / 3.6 GHHz /32 GB
Pro Tools 2018.10.0, Eucontrol 3.0.244
Artist Control is latest version latest firmware, Artist Mix is one firmware version behind.
I am using an ethernet port for one of the surfaces and a USB to ethernet for the other. Not using a switch or a hub.
I have the ports set to 10.0.0.2 and 10.0.0.3 and the surfaces to 10.0.04 an 10.0.05. With the subnet mask to 255.255.0.0 for everything.
I can get Eucontrol to briefly see both surfaces in the application but it immediately stops responding. If I turn off either the control or the mix the other unit works.
Any suggestions?
I see in the set up guide (why did I not read this first) that I need a router or switch. I will try that. I think I was fooled by everything showing as connected in the network set up.
Last edited by Nick Namnone; 03-28-2019 at 12:02 PM. Reason: found more information. possibly solved problem
Old 03-31-2019, 03:44 PM
robertg robertg is offline
Default Re: can't get Artist Control and Mix to work at the same time-Never mind. I need a ro
Any suggestions?
A switch..
Old 04-05-2019, 01:39 PM
MoPro's Avatar
MoPro MoPro is offline
Originally Posted by robertg View Post
A switch..
What he said!^^^
I use a DLink DGS-1005G, 5 port Gigabit switch.
Static IP's for the controllers, and on an isolated network... My motherboard has two hardwired network connections, so I use one for the Avid controllers, and the other for the internet.
I have never had the controllers drop the connection, and it is rock solid!
Al
Computer Asus P9X79 Deluxe | Intel i7 3930k | 32 Gig Ram | Intel 520 SSD's | 2T Caviar Black
Software Win 7 Ultimate (64bit) | Cubase Pro 9.5.41 (64bit) | WaveLab 9.5.25 (64bit) | HALion 6 (64bit)
Hardware RME FireFace's UFX / 800 | MOTU MTP AV USB | Avid Artist Series: Control, Mix, and Transport | EuControl ver. 18.3
New to artist control- not all functions work [email protected] Artist Series 0 12-18-2017 07:50 PM
Getting Artist Mix and Control to work with Studio One v3 michaelhulse Artist Series 2 07-23-2017 04:48 AM
I can't use my Artist control and the iPad app at the same time. robertg Artist Series 14 08-13-2015 11:47 AM
Euphonix Artist Control doesn't work on Logic Pro X :( karhariasgr Artist Series 33 02-10-2014 01:56 AM
Artist Control & Mix do not work with PT 11.1 Franklyn Artist Series 3 01-10-2014 10:03 PM
