Old 03-07-2019, 04:15 AM
Herge Herge is offline
Default Freezing faders on mix window
Hello,
I got a really strange issue with Pro tools 12.8.2 :
Sometimes, all faders in the mix windows become randomly frozen (so in the S6 too..) : You can still edit, add insert and edit insert, create manually some automation, they will be written. But you can’t access to the faders on the mix window and the pan also : they are frozen.
The only way to get them back is to quit pro tools (no need to force quit) and launch again.
It happened on several pro tools session with different medias.
The issue happens randomly. The last time I tried, I had the problem on a session three time (so after 3 relaunch) at the same moment : juste after launching this session, everything works fine but when starting recording and writing autom, the freeze appears instantly...
Any idea please ?
system configuration :
Pro tools HD 12.8.2
Z440 Single 6-Core Intel Xeon E5-1650v4 3.6GHz with 32Go Ram and SSD 250 Go
1x HDX card and MTRX
1x Kona LHi (driver v15)
1x S6 M10 16 faders (Eucon v18.3)
Old 03-07-2019, 10:21 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Freezing faders on mix window
Weird problem - I'd try trashing preferences and a clean reinstall of Pro Tools.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 03-09-2019, 01:53 AM
Hi Chris,
I tried a lot of things yesterday :
- working in local, without active directory and leaving the domain ; same issue.
- trashing PT prefs and a clean reinstall of Pro tools and plug-ins ; same issue.
- Use another Z440 with other HDX card, other AJA card, other GPU card, new install ; same issue.
The only thing I did not try is to do my tests with another template. Also there is some third party plug-ins installed and used in this template : Sonnox DSP, Waves... I will try without them.
Old 03-14-2019, 02:46 AM
Hello,
For the moment I found a workaround : If I do not start the record at session start, the problem does not appear. So I just need to put session start to 00:58:00:00 for exemple and start the first clip at 01:00:00:00 where I put a "start" marker.
This works, but it's just a workaround....
Mix window freezing in 8.0.3 windows 7 32 gringojeff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-22-2010 05:17 PM
Meters and Faders not working/freezing ouijibill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-11-2006 05:27 AM
Faders Freezing After Bounce To Disc Azrael Pro Tools TDM Systems (Mac) 1 04-07-2002 01:11 AM
FREEZING FADERS- HELP PLEASE! flymax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-15-2001 10:46 AM
HELP! My Mixer Faders Keep Freezing Up! flymax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-22-2001 12:23 AM
