Old 07-31-2019, 10:13 PM
mholley mholley is offline
Default New computer, a couple of error messages...
Good Evening,
I just put the most recent version of PT 2019 on a Mac, and my PT files are on an external drive, that I used on my old Mac. Any idea what would cause these errors to come up? One is while trying to save the file, and the other for auto back ups.
I am on the most recent Mojave operating system.
Thanks,
Mark
File Type: jpg 654763EE-D943-4128-B8B9-787E51EE2CA4.jpg (75.5 KB, 0 views)
File Type: jpg 239B6A48-01C9-4852-91F9-6BF75B64E51B.jpg (53.3 KB, 0 views)
Mac Mini, 32 gig Ram, OS X 10.14.4 - Mojave, Scarlett, PT 2019.6
Old 07-31-2019, 10:31 PM
BScout BScout is offline
Default Re: New computer, a couple of error messages...
What is the format of your external drive? Did you format with permissions enabled? If so, that’s your problem. All your files belong to the “user” of your older computer (doesn’t matter if you use the same username on both).
Sorry, should have mentioned the solution. Find the drive on your desktop, click "Get Info", at the bottom unlock the options by clicking on the lock and entering your password, then choose the checkbox "Ignore Ownership on this volume"
Old 08-01-2019, 07:38 AM
arche3's Avatar
arche3 arche3 is offline
Also check in protools workspace. Make sure drive is set to record and playback. If it's not a permissions issue from previous post.
Sent from my SM-G975U using Tapatalk
Old 08-01-2019, 04:43 PM
Thanks all,
I'm kinda stumped...when I go to the hard drive, I don't have the "ignore ownership this volume" option, and all accounts are set to read & write.
In workspace, permissions are set to "r".
Any other ideas?
Thanks,
Mark
Old 08-01-2019, 04:54 PM
Post a screen shot of your "get info" of that drive
Old 08-01-2019, 05:02 PM
Will do! I’ll head back to the computer in a bit. Appreciate you looking at it.
Mark
Old 08-01-2019, 05:18 PM
Here you go! Appreciate any insights...
Mark
File Type: jpg F4E3A3BF-09E7-40AB-A937-F2FE0ADFB104.jpg (82.1 KB, 0 views)
Old 08-01-2019, 05:56 PM
I see this is a timemachine backup drive. I think that complicates things as permissions/ownership needs to remain.
Post a screenshot of the drive in diskutility. Looking for the info in the lower right side where there will be an entry for "owners"
Old 08-01-2019, 06:57 PM
Ok,
Here is a pic where it says enabled, but still has the same error messages...
And another pic with info...
Thanks again,
Mark
File Type: jpg 42B9DB6A-2088-4766-AB08-0A07AFC9FD52.jpg (75.1 KB, 0 views)
File Type: jpg 98449EBE-58B0-48D4-9065-3F2A6157B61D.jpg (87.7 KB, 0 views)
Old 08-02-2019, 05:35 PM
Good Evening,
I have been scouring the internet, as well as the help us help you here on the DUC, with no luck...any ideas?
I have some tracking to do, and this is a stumbling block....
Thanks as always!
Mark
Couple of question about Protools 9 & new computer Loyd981 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-07-2010 07:07 AM
Many different error messages, Pro Tools aborting or unable to click messages off riffmachine Pro Tools M-Powered (Win) 5 10-05-2010 04:15 AM
Help with 9.2.2 / 5.01 Error 10 messages soundboy35 Pro Tools TDM Systems (Mac) 7 03-05-2003 09:09 AM
ERROR MESSAGES! HELP! ddrive 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-17-2002 10:59 AM
too many error messages using a p4 1.7 ghz hank hill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 02-10-2002 05:13 AM
