recording acoustic stuff - questions
Hey just wondering what everyone's mic choices would be for a double bass (stand up) without pickups and a viola?
Actually its a quartet (2 acoustic guitars, double bass and viola)....any suggestions on how to mic that? (no amps all acoustic) Thanks! |
Re: recording acoustic stuff - questions
I'd use stereo XY + a room mic.
The x/y is natural way to go, especially if you've got a nice room. If you are wanting to mix and have some isolation of tracks, or have a small room CLOSER mic'ing may be in order. I don't say CLOSE mic'ing because violins and violas are tough to close mic and not get a raspy sound. (this is not the player's fault but the nature of the instrument. ok a bad player can sound bad at any distance...) Up close a violin/viola doesn't sound that pleasant so getting the mic away a couple feet will help.
Depending on the style I have good luck with ribbon mic (rca 77d) on upright about 18" away, about halfway between the bridge and the heel putting slightly downward. Guitars - classic method, small diaphragm condenser diagonally pointing in to the 12th fret, large diaphragm pointing in toward the saddle. Violas - from above with large diaphragm, not directly above, but at an angle pointing towards the bridge. Set the booms so you're clear of the bows. Nothing will intimidate a violist/violinist more than having any impediments to their bow arms. (don't get me started on viola jokes... that's a whole new thread)
Mpowered PT w/ProjectMix with Black Lion mods, and Transit, Macbook Pro, Reason, Live, Axiom 25, Keystation 88, Coffee with cream, no sugar |
ORTF - much bigger sound field than XY or MS. I use an ORTF setup for all my classical/audiophile recording. To enhance the depth and ambience, try flanking an omni several feet to each side of the ORTF pair and a few feet back.
You may need to use a spot on the bass (if the player is doing mainly pizzicatto - if he's bowing he'll be loud enough). Depending on the guitars, they may also need a spot. If they are well rehearsed and play well with each other, they will balance themselves and you won't need to worry about spots at all. You may just need to make a few gentle comments to help them balance in the room. Orchestra strings radiate their sound up and out - so keep that in mind when setting up the mics. HTH
Steve Always err on the side of perfection. |
Hey this is what came out...I did it in a bit of a rush and it was a free job so I didn't go too crazy with mics.... Have a listen if you are interested..
http://www.lastounce.com/puppet1.mp3 Comments are very welcome |
Typically I use a single Audio Technica 4041. IT varies from instrument to instrument where exactly ti ends up, but typiclally somewhere around where the neck ends, usually on players left side, and about 2-3 feet away.
Frfr questions, 11r, acoustic and vocals.. do I need a mixer? | webstersp | Eleven Rack | 11 | 12-30-2011 10:03 PM |
Recording Acoustic Guitar Questions | ryananiol | Tips & Tricks | 25 | 12-21-2009 08:46 AM |
Panther upgrade questions . . .basic stuff really. | chagos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 06-29-2004 10:56 PM |
Lucid D/A - Digi001 hookup questions and other stuff | The Mighty Burner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-27-2003 07:20 AM |
questions on Roland stuff.... | pk_hat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 01-31-2002 11:26 AM |
