Old 07-10-2000, 06:39 PM
jang kyung won jang kyung won is offline
Default -6031error with logic
How can I resolve above problem?
computer:Power Mac 9600/200
Ram : 128MB
sofrware : Logic 4.1 Platinum
Protools le 5.0.1
I have been in trouble with digi001 I/O box
while performing logic.
That is direct I/O ERROR.
Who can help me about this problem?
I'll wait someone who is genius.
Thaks a lot
Old 07-10-2000, 08:52 PM
dukewalters dukewalters is offline
Default Re: -6031error with logic
I've had the same problem. Logic I understand is working on solving this problem. There is a conflict between 4.2.2 and PT 5.0.1. You should downgrade to 5.0 and wait till they figure out the bug. You shouldn't hace any problems with 5.0
Old 07-13-2000, 05:58 PM
DigiTechSupt's Avatar
I have experienced this error as well. My system:
Beige G3/266 DT
OS 9.0
Logic 4.2.2
DAE, DSI, Direct I/O, Digi001 OMS Driver (all version 5.0.1)
Apparently, the error has something to do with too many interrupts happening at once. We are currently looking into this issue with Logic and hope to work towards a resolution.
Brent
Avid Audio Tech Support
Support FAQ
Old 08-29-2001, 06:16 PM
ThomCat ThomCat is offline
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by DigiTechSupt:
Brent
<HR></BLOCKQUOTE>
Well, its been over a year. Searching the DUC has yielded no answers. I have used all Logic versions 4.2 to 4.7 and all of them still are plagued with -6031 errors when using DIO.
What have been the results of your colaboration with Emagic to resolve this issue?
Old 08-29-2001, 06:31 PM
Kickin.da.speaker Kickin.da.speaker is offline
Weird. I'm using 4.7.0 and don't have this problem. Are you using all 5.1 PTLE extensions? (DIO, DSI...) Maybe that would be the problem?
Check out this page http://www.digidesign.com/download/protools.html
And download DSI 5.1, Direct I/) 5.1.1 and DAE 5.1, install and see....
David.
6am eternal
Old 08-30-2001, 02:20 PM
I run Logic with .125 buffer size (smallest available) all the time and never get those errors. When the amount of audio tracks gets really really huge for my HD/CPU, I increase the buffer size, but I don't suffer from this problems, and neither should you.
Have you tried my solution?
David.
6am eternal
Old 08-30-2001, 02:47 PM
marina marina is offline
hi
i just got the digi001 and set it up with logic 4.7, it makes pop/crackle noises, does anyone here know about that?
and also get the -errors but after i hit play several times it stops then comes back, pro tools is perfesct other then the buffer thing, but logic is a mess, i use a dual 450 and i tried everything, i have to de activate dio to move on with tracks recorded in pro tools and imported into logic [img]images/icons/frown.gif[/img]
im blonde, blue eyes and love Macs and Pro Tools
Old 08-30-2001, 03:32 PM
marina, what version DIO, DigiSystemInit do you use? What OS?
David.
6am eternal
Old 08-30-2001, 06:01 PM
( KICKING DA SPEAKER)
i have all the latest 5.1 updates,
some one sugested i ask users here on the duc what they are doing to get around the problem?
if you do not mind me asking, , what is your configeration extensions or whatever it took to get it working?
thank you very much
Old 08-30-2001, 06:40 PM
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by Kickin.da.speaker:
...Are you using all 5.1 PTLE extensions? (DIO, DSI...) Maybe that would be the problem?...And download DSI 5.1, Direct I/) 5.1.1 and DAE 5.1, install and see....<HR></BLOCKQUOTE>
David...
Thanks for replying. I'm still a litle confused by your possible solution, however. I am running the three original Digi extensions that came with the 5.0 CD/Digi 001. I'm still not sure which of them (if not all) are required for the hardware and which are just for the PTLE software. Since I don't use the software for anything other than a coaster, I might be able to turn one or more of them off, but which ones? And would I really even need to install DAE? (DP500 G4 native/Digi 001/Logic only).
Since I know you to be a big Logic guy, if you could would you post which Digi extensions you are using and their versions, and I will try to replicate that on my system and see if that helps. I will download the 5.1 versions of all three in the mean time. Thanks.
'Cat
P.S. Do you think Digi Tech Support will have found an answer by now? After the statement from Brent all of the posts eventually just evaporated.
Logic 8 to logic 7 session won't open! saving procedure need crizdee Pro Tools TDM Systems (Mac) 9 04-26-2008 08:09 PM
Logic Pro users: Midi & audio between Logic & PT dtmprod Pro Tools TDM Systems (Mac) 4 09-24-2006 04:16 PM
Logic 5.0.0 crashes all the time.. Is there a Logic expert around here? uno1234 Pro Tools TDM Systems (Mac) 13 04-28-2002 04:23 PM
RTAS & Logic? VST plugs on Logic? Jules Pro Tools TDM Systems (Mac) 3 05-24-2001 10:16 AM
Hello Logic users.......Please explain about Logic Midi elik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-04-2001 12:35 AM
