Old 06-21-2019, 09:41 PM
ToneSetter ToneSetter is offline
Default What to look out for when buying a D-Command
I'm going to be buying a blue D-Command once I can find a good price on ebay or reverb. What type of things should I look out for? Like ways to tell if things are wrong or something. Like ways to tell if faders, power supplies, etc are going bad or are bad. Not really sure what to ask, I just don't want to get ripped off. $2000 to $3000 isn't really spare change to me. Thanks for the help
Old 06-21-2019, 10:20 PM
BScout BScout is offline
Default Re: What to look out for when buying a D-Command
Put it in Vegas mode to check faders, knobs, lcds, leds. And then carefully scan every part while they are in motion/blinking.
As for power supplies, at the age they all are, they will need to be replaced. If they’ve been replaced in the last 5 years, you’ll be good for a while. If they haven’t, expect to. Not an expensive replacement. The fader and led power supplies are the ones that need replacing as maintenance. The control power supply rarely needs replacing (found only in the main unit.) (Main unit has 3 power supplies, add on fader packs have 2 power supplies. So a 24 fader d-command has 5 power supplies total)
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 06-21-2019, 10:53 PM
YYR123's Avatar
YYR123 YYR123 is offline
Yep I agree with Scout
And you will wonder how you ever lived without it once you get it
Great surface
Daniel
Old 06-25-2019, 02:31 PM
ProtoolsLover ProtoolsLover is offline
Make sure it comes with an xMON. Any 9 pin serial cable will work by removing one of the pins from both sides, I'm pretty sure it was the 6 pin, but that's easily found out online.
I have a 24 channel board, that I paid less than 2k for over 3 years ago, and it's still mint today.
Good luck!!!!
Old 06-25-2019, 06:50 PM
Good luck!!!!
Wish I could find a 24 channel for 2k. I can't even seem to find a main unit for under 2k that's in good condition without problems
Old 06-25-2019, 08:13 PM
My situation was a complete fluke!
Old 06-26-2019, 12:12 AM
Led Led is offline
There was a blue 24 channel that went for not much more a few weeks ago on ebay, it was pick up only located in Brooklyn. From a studio liquidation. Last I saw they still had a blue 8 fader main unit going for about $1300...Save a search on ebay as "D Command" and you'll find something at some point. There is/was a 16 fader D Control on there for somewhere around 3K recently as well, but they hurt your arms to reach all the controls.
Andy Evans
Sound Designer/Composer/Mixer
Melbourne, Australia
www.mud.net.au
advice on buying a D-Command MarcOliver ICON & C|24 10 04-15-2016 05:43 AM
Worth buying a Command 8 now? Morning ProControl, Control|24, Command|8 16 10-30-2010 06:15 AM
I am buying this D-Command dsstudio ICON & C|24 6 12-18-2008 07:10 PM
Total Loss of Command 8 Command/Modifiers John Pisciotta ProControl, Control|24, Command|8 1 05-13-2005 10:30 AM
HELP! I am buying a Dell Laptop with intent on buying a DIGI 001 as well xian$ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-18-2003 11:53 AM
