Old 03-05-2009, 04:30 PM
BigMeany BigMeany is offline
Default Digi Plugins Causing Audio to Cut Out
So this problem has gotten progressively worse over time, Your working in a session and you close that session...Then you reopen it and just about every track with a digirack TDM plugin on it, will not play audio.
If you remove the digi plugin the audio plays, If you put the TDM plugin back on the track, The audio completely cuts out again.
If you then remove the TDM plugin and put the exact same RTAS plugin on that track, The audio will play again.
If I use the Pref/Database trasher and restart, I can put the TDM plugins back on the tracks and it will work again until I open the session at a later date and the process repeats itself.
This is happening pretty much everyday now.
OS 10.4.10
PT HD 7.3.1 cs5
Mac Pro Quad 2.66
5 Gigs Ram
Old 03-05-2009, 04:50 PM
DigiTechSupt's Avatar
Default Re: Digi Plugins Causing Audio to Cut Out
This is usually caused by having incompatible plug-ins installed.
Can you use the Tech Support Utility referenced in the General Troubleshooting thread to generate and post a plug-in version list?
Avid Audio Tech Support
Support FAQ
Old 03-06-2009, 01:23 PM
Fri Mar 6 16:19:58 EST 2009
Pro Tools Version
__________________________________________
Pro Tools HD.app
7.3.1cs5, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc.
Plug-In Versions
Access Music Indigo.dpm
7.2, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc.
Amp Farm.dpm
3.10, Copyright 2006 Line 6
Auto-Tune_TDM.dpm
5.0.6, Copyright © 2006 Antares Audio Technologies
BF Essential Clip Remover.dpm
7.3, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc.
BF Essential Corr.dpm
BF Essential Meter.dpm
BF Essential Noise.dpm
BF Essential Tuner.dpm
BFD Lite.dpm
1.0x0, Copyright 2006 FXpansion Audio UK Ltd..
BFD Lite.plg
BFD version 1.5.0.45, Copyright 2003-2006 FXpansion Audio UK Ltd.
Broadband Noise Reduction LE.dpm
Broadband Noise Reduction TDM.dpm
Bruno.dpm
Chorus.dpm
Click.dpm
Cosmonaut Voice.dpm
D-Verb.dpm
DigiReWire.dpm
Dither.dpm
Dynamics III.dpm
EMI TG 12413 UB.dpm
1.1.7, Copyright 2005, All Rights Reserved
EQ III.dpm
Echo Farm.dpm
2.30, Copyright 2006 Line 6
Factory Promo.dpm
1.2.1 Promo, Copyright 1991-2007 Eventide, Inc.
Fairchild 660.dpm
Fairchild 670.dpm
Flanger.dpm
Focusrite d2.dpm
Focusrite d3.dpm
Funk Logic Masterer.dpm
Harmony4.dpm
Harmony4 1.2.00 © 2007 TC Helicon Vocal Technologies - All rights reserved
Impact.dpm
Invert-Duplicate.dpm
JOEMEEK Compressor.dpm
JOEMEEK Meequalizer.dpm
LoFi.dpm
MDW_EQ2_3B.dpm
2.0.2r47, Copyright 2007 Massenburg Design Works.
MDW_EQ2_5B.dpm
MasterX3.dpm
MasterX3 4.0.01 Beta © 2006 TC Electronic A/S - All rights reserved
Maxim.dpm
MelodyneBridge.dpm
Mod Delay II.dpm
Multi-Tap Delay.dpm
Normalize-Gain.dpm
Phoenix.dpm
2.4.3x22, Copyright 2002-2006 Crane Song Ltd.
Ping-Pong Delay.dpm
Pitch 'n Time Pro.dpm
2.4.0.8, Copyright 1999-2007 Serato Audio Research
Pitch.dpm
Purple Audio MC77.dpm
ReVibe.dpm
RectiFi.dpm
Reso.dpm
Reverb One.dpm
Reverse-DC Removal.dpm
SansAmp PSA-1.dpm
SciFi.dpm
Signal Generator.dpm
SignalTools.dpm
Sonic NoNOISE.dpm
SonyOxfordDynamics.dpm
1.6.1, Copyright 2007 Sonnox.
SoundReplacer.dpm
SoundToys
Stereo Mixer.dpm
Surround Mixer.dpm
Synchronic.dpm
TL Drum Rehab.dpm
7.4, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc.
TL InTune.dpm
TL MasterMeter.dpm
TL Metro.dpm
TL Space.dpm
Tel-Ray Delay.dpm
Time Comp-Exp-Pitch Shift.dpm
Time Shift.dpm
7.3, Copyright © 2005 by Digidesign, a division of Avid. All rights reserved.
TimeAdjuster.dpm
Trim.dpm
VariFi.dpm
VocALignPro.dpm
4.1.1, Copyright 1995-2007 SynchroArts Ltd.
VocALignPro.pdf
Voce Chorus-Vibrato.dpm
Voce Spin.dpm
bombfactory BF-3A.dpm
bombfactory BF76.dpm
moogerfooger AD.dpm
moogerfooger LP.dpm
moogerfooger Ph.dpm
moogerfooger RM.dpm
Plug-Ins Unused Versions
AVOX ARTICULATOR.dpm
1.0.0, Copyright © 2008, Antares Audio Technologies. All Rights Reserved.
AVOX ASPIRE.dpm
AVOX CHOIR.dpm
1.1.4, Copyright © 2008 Antares Audio Technologies. All Rights Reserved.
AVOX DUO.dpm
AVOX MUTATOR.dpm
AVOX PUNCH.dpm
AVOX SYBIL.dpm
AVOX THROAT.dpm
AVOX WARM.dpm
Dynamics II.dpm
EQ II.dpm
Harmony Engine.dpm
1.0.3, Copyright © 2008 Antares Audio Technologies. All Rights Reserved.
Stereo Dithered Mixer.dpm
Surround Dithered Mixer.dpm
WaveShell-DAE_5.9.1.dpm
bombfactory BF-2A.dpm
Toolkits and Digitranslator Versions
Music Production Toolkit is not installed
DV Toolkit 2 is not installed
Digitranslator 2 is not installed
Digitranslator 1 is not installed
Old 03-09-2009, 04:12 PM
So,
I decided to buy a new hard drive (7200 32) reinstall the OS, Reinstalled Pro Tools, Did updates, Installed a extremely scaled down set of plugins from the list above and guess what?
My digirack plugins are still doing the same thing, This is a major problem...Very annoying and wrecks a workflow from the get.
If its not outdated plugins causing my problem than what is?
Old 03-09-2009, 06:07 PM
JC925602 JC925602 is offline
Originally Posted by BigMeany View Post
...If you remove the digi plugin the audio plays, If you put the TDM plugin back on the track, The audio completely cuts out again.
If you then remove the TDM plugin and put the exact same RTAS plugin on that track, The audio will play again....
Could it be a bad DSP chip? You can lock out a chip in the system usage windows by clicking on a chip. You can also disable DSP caching as your problem seems to be on reload of the session.
Try this: purge the DSP cache before reopening the session.
After that, you can try to disable some chip to see if the problem persist. If the problem is linked to a specific chip then you will know.
JC
Old 03-10-2009, 07:01 AM
SmithLeeProductions SmithLeeProductions is offline
I had this exact problem a while ago. I can't remember exactly what the fix was but I THINK the digi rep is right. I believe I has some freeware rtas or maybe even a wrapped VST that was causing this to happen.
Sorry I can't be more specific, it was over a year ago.
Justin
Old 03-10-2009, 07:17 AM
tonwurm's Avatar
tonwurm tonwurm is offline
Originally Posted by JC925602 View Post
...You can also disable DSP caching as your problem seems to be on reload of the session.
Try this: purge the DSP cache before reopening the session...
he´s on 7.3, no caching / purging with this version
Mac Pro 2010 - PT10 HD3, PT12 HD, Logic X, DP 7, VEPro, OSX 10.9.5 / 10.12.6
MacBook Pro - Logic X, Mainstage
Old 03-10-2009, 09:08 AM
I suspect a corrupted plug-in - can you remove all the 3rd party plug-ins, trash prefs and test again?
Have you tried running Digitest yet?
Support FAQ
BFD causing audio freeze in PT 8 joedexter23 The Drum Room 1 03-26-2012 09:09 AM
Waves plugins causing phasing tobias bluth macOS 2 02-09-2011 02:26 AM
Updated Waves Plugins causing mouse/002 issues? Longshanks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 06-10-2010 04:18 AM
Plugins causing latency upon playback powerhouse0111 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 04-01-2010 06:38 AM
Mbox and Digi Core Audio driver causing freezes Matthew Cochrane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-25-2004 08:54 PM
