Bussing and Latency
Did a search. Came close, but did not find this exact problem. Here's a chain: Vox (audio) sent to three auxes (Sat, Verb, and Vox Master) Sat is sent to verb and vox master. Verb is sent to Vox master. And here's the problem: Just having the buss on the Sat track that sends sat to Verb creates latency (audible doubling) EVEN WHEN THE TRACK IS MUTED. Remove that send from that track and the latency goes away. I set I/O to default. No change. Note that I am NOT bussing to a record enabled audio track. I did see some threads and videos about that issue. This is a little different. I do have several workarounds for this, but what is going on here? Thanks!
Mac Mini Server Quad Core I5 16gig RAM Mavericks 10.9.5 PT 11.3 |
Re: Bussing and Latency
I think you have time alignment problems with the reverb being on too many sends folding back or something. I would suggest doing separate reverb aux's for each vox and sat and see if that cures it . I am not if front of my system to test so maybe someone else has a better solve?
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
Pretty sure this is a known issue that has yet to be fixed. Best bet is to not route a bus thru a second bus(until it really gets fixed). Everyone has their own favorite workflow, but sometimes PT just doesn't cooperate If the Vox Master has plugins, that's going to require a new thought process. If its just to have a single fader controlling several, maybe use a VCA fader(and remember that AUX tracks that are fed by post-fade sends, do not need to be ridden by the VCA as their input level will follow)
I failed to mention that this happens when there are no plug ins at all on any of the channels. They are not bypassed, either. There are none. This is just the routing.
It seems that this workflow would be common and that Pro Tools would make sure that it's possible to do. I've never used VCA faders before. I have other workarounds, but I also like that one. If anyone else has any ideas about how/why this is happening, I'd love to hear it.
Latency With Bussing | midnightsun | Pro Tools HDX & HD Native Systems (Mac) | 4 | 12-25-2017 07:15 PM |
Latency when bussing to an aux? | kevinb511 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-16-2007 12:07 PM |
Bussing and Latency | Orange Worker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 11-22-2005 01:57 PM |
Bussing latency? | sgladm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-04-2005 09:03 PM |
Latency and Bussing | rockwithrespect | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 05-11-2005 10:51 AM |
