Pro Tools requires version 9.0.6 or later, but CFnd provides version 9.0.0
Hello, I have had so many issues with AVID software, my latest is that after so long the computers decide to get this error, i have previously clean uninstalled and reinstalled and it works for so long then reverts back to this. I have also rebuilt machines so they're fresh and it still after so long comes to this conclusion. I am losing my mind, Avid offerer no support without me coifing up money for there software errors. I have 18 Macs that run this and all have the same issues. I have 15 running Pro Tools Express and 2 Running Pro Tools 9 and they both have the same issues just different version errors.
Below is the report of the error. Process: Pro Tools [6991] Path: /Applications/Digidesign/*/Pro Tools.app/Contents/MacOS/Pro Tools Identifier: com.digidesign.ProTools Version: 9.0.6 (9.0.6f82) Code Type: X86 (Native) Parent Process: launchd [5950] Date/Time: 2014-02-05 12:24:16.150 +0000 OS Version: Mac OS X 10.7.5 (11G63b) Report Version: 9 Interval Since Last Report: 1036 sec Crashes Since Last Report: 3 Per-App Crashes Since Last Report: 2 Anonymous UUID: B53AC67E-043F-4AE4-BFC8-47C213828082 Crashed Thread: 0 Exception Type: EXC_BREAKPOINT (SIGTRAP) Exception Codes: 0x0000000000000002, 0x0000000000000000 Application Specific Information: dyld: launch, loading dependent libraries Dyld Error Message: Library not loaded: @executable_path/../Frameworks/CFnd.framework/Versions/A/CFnd Referenced from: /Applications/Digidesign/*/Pro Tools.app/Contents/MacOS/Pro Tools Reason: Incompatible library version: Pro Tools requires version 9.0.6 or later, but CFnd provides version 9.0.0 Binary Images: 0x1000 - 0x19cfe3 +com.digidesign.ProTools (9.0.6 - 9.0.6f82) <9E5E0CB1-5B9E-0EE1-D7A0-E097E74FF413> /Applications/Digidesign/*/Pro Tools.app/Contents/MacOS/Pro Tools 0x3f5000 - 0x61efeb +com.digidesign.framework.CoreFoundation (9.0 - 9.0f121) <24A052BC-E7AA-7320-7244-3CEECCB2335C> /Library/Frameworks/CFnd.framework/Versions/A/CFnd 0x8fe06000 - 0x8fe38aa7 dyld (195.6 - ???) <3A866A34-4CDD-35A4-B26E-F145B05F3644> /usr/lib/dyld Model: iMac12,1, BootROM IM121.0047.B1F, 4 processors, Intel Core i5, 2.5 GHz, 4 GB, SMC 1.71f22 Graphics: AMD Radeon HD 6750M, AMD Radeon HD 6750M, PCIe, 512 MB Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1333 MHz, 0x02FE, 0x45424A3230554638424353302D444A2D4620 Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1333 MHz, 0x02FE, 0x45424A3230554638424353302D444A2D4620 AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x9A), Atheros 9380: 4.0.67.5-P2P Bluetooth: Version 4.0.8f17, 2 service, 18 devices, 1 incoming serial ports Network Service: Ethernet, Ethernet, en0 Serial ATA Device: ST3500418AS, 500.11 GB Serial ATA Device: OPTIARC DVD RW AD-5690H USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x850b, 0xfa200000 / 3 USB Device: hub_device, 0x0424 (SMSC), 0x2514, 0xfa100000 / 2 USB Device: Mbox, 0x0dba, 0x5000, 0xfa120000 / 5 USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfa130000 / 6 USB Device: Apple Optical USB Mouse, apple_vendor_id, 0x0304, 0xfa133000 / 9 USB Device: Apple Keyboard, apple_vendor_id, 0x0250, 0xfa132000 / 8 USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 4 USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0xfa111000 / 7 USB Device: hub_device, 0x0424 (SMSC), 0x2514, 0xfd100000 / 2 USB Device: iLok, 0x088e, 0x5036, 0xfd130000 / 6 USB Device: Oxygen 49, 0x0763 (M-Audio), 0x2027, 0xfd140000 / 5 USB Device: Internal Memory Card Reader, apple_vendor_id, 0x8403, 0xfd110000 / 4 USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd120000 / 3 Cheers Luke.
Luke Wakefield IT Service Engineer |
Re: Pro Tools requires version 9.0.6 or later, but CFnd provides version 9.0.0
Jonathan S. Abrams, CEA, CEV, CBNT Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10) Last edited by Chief Technician; 02-05-2014 at 05:23 AM. Reason: accuracy |
Most likely they will have been updates. Would you require to know which ones? Cheers Luke.
The task you have before you is to determine which update broke Pro Tools. In the interim, what happens if you do a clean uninstall of v9 and then reinstall v9?
I shall start looking into which update is the culprit, When I clean uninstall V9 and reinstall it does the same as Express, breaks after a while.
Have you any possible inkling into what type of update might cause issues like this?. Thanks for your time by the way, really appreciate it. Luke.
When you update do you allow the software updater to run and update automatically (I never do) or download and manually update using the combo updater (I only do this).
Have you tried applying the combo-updater for OS X 9.0.6?
Pro Tools, Studio One Pro 2022 Mac Studio M1 Max 64GB-1TB NVME OWC Thunderbay Mini (4TB SSD) OWC Express 4M2 (4 X 2TB) Interface: Presonus Quantum Presonus Faderport & Faderport 8 Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128 BM5A, KRK VXT4, Equator D5 2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig) |
I do not. If you can figure out which update breaks Pro Tools, that might lead me to a few ideas.
We deploy our updates via workgroup manager.
Mbox 2 Driver 9.0.mpkg Avid Mbox Pro.pkg Avid Mbox.pkg Mbox 2 Pro Driver 9.0.mpkg could these have any bearing on my problem?
It's a chunk of code that Pro Tools relies on for operation. The version number would be for Avid's tracking purposes.
Possibly. Does Pro Tools work properly before those packages are installed? Does Pro Tools stop working properly after those packages are installed? Do the workstations you manage use either an Mbox or an Mbox 2 audio interface?
Reason: Incompatible library version: Pro Tools requires version 9.0.6 or later, but | Patrick H | macOS | 3 | 11-20-2012 02:46 PM |
This version of Strike requires authorization for you to use it. | jackshocklee | Virtual Instruments | 6 | 01-12-2011 10:56 AM |
Incompatible library version: CFnd provides version 7.2.0 | heshion | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-24-2009 03:42 PM |
This version of Pro Tools requires DAE version 5.1 or later. | Josh Jagdfeld | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 10-09-2007 03:31 PM |
"This version of ------- requires authorization" ? | tamashii | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-04-2006 07:30 PM |
