003 quits Pro Tools 9.0.3, please avid staff..
I know there is no LE versions anymore, but since I don't have HD, allthough CPT, I reckon this is the right place.
Every now and then, and more often now than then...., Pro Tools unexpectedly quit, giving me a looong list of errors, restarting won't help even with a power off/on on my 003 rack+. Only way to solve is to restart my Mac. I'm on 10.6.8. This problem occurs often, sometimes even several times within half an hour. I do not record to any of my firewire disk, they're all set to transfer only. Recording is only set to my internal disks. The only firewire gadget I have is a FW to DV box, canopus, which has worked flawless in the past with other versions. I've tried to dump all my preferences and stuff with pro tools helper, but no luck. When I switch to pro tools aggregate this problem is solved. Anyone else have this problem? I've got the latest drivers for the 003. Biggest problem is when I'm downmixing half an hour films to stems and it force quits half way through... I would certainly hear from some avid guys on this one.. Mac Pro 1,1 Pro Tools 9 CPT MacOS 10.6.8 Canopus FW to DV 003 rack+ interface. Recording playback on internal disks, not system disk. Videoplayback from another disk than the audio playback/record. CPU/RAM values seems very good.
"Don't trust the boomer" |
Re: 003 quits Pro Tools 9.0.3, please avid staff..
Recording to the internal drive is not supported.
How much RAM? Are all plug-ins up to date? What troubleshooting have you done? Take a look here at the top of the page. Help us Help You - READ THIS Before Posting!
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Only if there is only one internal drive... And he says he isn't recording to the system drive.
DO NOT TURN ON AND OFF THE 003 UNIT WHILE YOUR MAC IS STILL POWERED ON!
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
I'm NOT recording to the internal SYSTEM drive, as you can see from my original post. AS I also said, I've deleted all files, like preferences and all the other pro tools system files. I used the pro tools helper application. I've never had this problem before, it was introduced with v9. it got worse with 9.0.3. Degrading to PT8 solved the problem, completely.
I've done as you said, upgraded all plugins to latest versions, I've also tried to remove all plugins other than the bundled ones. I tried to disconnect all other firewire devices, reinstalled Mac OS(v.10.6.8) I'm always updating Mac OS to latest versions. I've installed the latest drivers for 003, tried another FW port, and another FW cable. What else can I do..?
AVID staff please help with this question??? | TruestPain | Pro Tools 10 | 16 | 04-25-2013 05:02 PM |
Pro Tools 9 wont start! Quits unexpectedly.... Quits during startup... | dbC4G | Pro Tools 9 | 11 | 03-09-2012 07:23 AM |
A thanks to the Digi staff ! | SteveH44 | Post - Surround - Video | 4 | 09-25-2005 07:33 AM |
to DIGI staff | daven | Pro Tools TDM Systems (Mac) | 3 | 01-27-2003 03:14 PM |
i gets no love from pt staff | pimpalicous | Digidesign Hardware & Software | 3 | 03-21-2001 08:41 AM |
