  #61
Old 10-13-2018, 08:23 PM
arche3's Avatar
arche3 arche3 is offline
Default Re: -9093 stops are killing me!!!!!
Originally Posted by [email protected] View Post
I've asked here before- what's the best video card people use for a late 2012 mac pro and protools?
I use a r9,280x. But there isn't a best one. Just get the best one you can afford. At least 3gig memory. Use Google. There are a ton of threads on it. Not just from audio people.
  #62
Old 10-15-2018, 08:02 PM
685 685 is offline
I may try a new MSI RX 560
  #63
Old 10-20-2018, 06:13 AM
panamajack's Avatar
panamajack panamajack is offline
Originally Posted by The Weed View Post
Controlled Folder Access is part of Windows Defender. It's under Windows Defender>Virus & Threat Protection>Virus & Threat Protection Settings>Manage Controlled Folder Access. It's Ransomware Protection and you can turn it On or Off, add Protected Folders and add or remove Allowed Apps. When it's turned on it stops any app/program that's not "Allowed" from making changes to the Protected Folders.
Obviously, if you're not running Windows Defender you don't need to worry about it. I have it "On" for my Work computer and "Off" for my Audio computer. I also now backup to an external drive and unplug that when done as well as have the paid version of Macrium Reflect which has Image Guardian, which is supposed to stop any Ransomware or Malware from encrypting any Macrium Reflect Image that's on a drive that has Image Guardian enabled on that drive. I unplug the drive because: If it's not connected it can't get infected.
SuperFetch and Windows Search are both under Control Panel>Administrative Tools>Component Services>Service (Local)>Standard Tab. Double Click on the Name, then set Startup type: Disabled and Service status: Stopped, then Apply and Okay for each.
My pleasure.
If you're using a backup program - you really should be - and you have Windows 10 Pro, use the Group Policy Editor to also disable System Restore. That too may save you some CPU cycles.
Good stuff. Will get around to updating from Windows Millennium Edition soon.
PT10.3.10HD(Tyan s2932 [8core Shanghai 2.7GHZ] 32GB,Win7 SP1); PT10HD(Tyan s2892 w/10GB, Win7 SP1);PT8HD(Dell 690 quad Xeon 3.0, 8GB, Win7,192 I/O, 96 I/O);MacBook Pro: 11R, Apogee Element 46, Focusrite 8PreX PT HD 11.3.2; Mac Pro 3.47 Hex 32GB, OSX 10.12.6/L10.4.2;L9.1.8, 2.64TB; G5 D2.3 4GB, 10.4.11/L8; 12c MP 2.66/32GB PT12.4; Structure, GigaGS3, Kontakt 5, Garratin, Sibelius 8.7+, Finale26,EMU,Vegas Pro 16-10/; RME HDSP9652,MOTU 2408 MKIII/1224/308, FX,Kurz,L5s,Strat,ASAT,JB,Zon
  #64
Old 10-22-2018, 08:40 PM
[email protected] pqlior@mac.com is offline
Hey man, I got the same card. What kind of cables did you get for it?
Are you using ther SATA power ones? I use all 4 drives in the MacPro, so don't have an open SATA power source...
Lior
HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 *
iPad Air/Avid control * EuCon 18.3.0.217 *
  #65
Old 10-22-2018, 11:15 PM
arche3's Avatar
There are 2 pcie power leads on the motherboard right next to the pcie slots. It's for the graphics card. 280x uses both of them.
Get whatever spec cable it needs. I think they are 6pin pcie power.
I use hdx cards so that used my power leads. So I got an external power supply.
I actually just got a rx580 pulse. For Mojave. But the 280x is also Mojave compatable so it works too.
  #66
Old 10-23-2018, 02:43 PM
Changed the GPU (R9 280X) and not much has changed... Still lots of 9093 and 9173 over here.
Lior
  #67
Old 10-23-2018, 04:14 PM
Did you see any improvement when switched from the R9 280x to the pulse?
Lior
  #68
Old 10-23-2018, 08:39 PM
arche3's Avatar
Did you see any improvement when switch from the R9 280x to the pulse?
Have not Installed it yet. Will do next week and see. Middle of a mix.
  #69
Old 10-25-2018, 09:46 PM
arche3's Avatar
Pulse better. More stable. CPU meter in protools spikes much smaller or non existent.
280 still had spikes but still worked 95% fine with few CPU error stops.
Also on hdx. When using say 5 or 6 vi inside Vienna ensemble with 3 Instances of maschine. 3 kontact. With 280x I can use 256 buffer with really no issue. On 580 pulse I can use 128. So its 1 playback better.
Only bad thing is the no boot screen on 580 pulse. Might setup my pcie chassis so I can have both 280 and 580 installed. For boot screen.
  #70
Old 10-30-2018, 07:40 PM
I was just going to say- I returned my pulse as I use the boot screen quite often for maintenance and troubleshooting...
Lior
MIDI Thru stops working after sequence playback stops kelcarpenter MIDI 20 03-16-2016 11:43 AM
11R killing PT thegreyfox Eleven Rack 3 04-24-2012 09:34 PM
This is KILLING me! audiogeekzine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 23 12-22-2008 04:10 PM
-9093 error's killing me!!! coryc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 10-04-2003 03:24 PM
-9093 Error, CPU stops rec., says buffer problem? storm-01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-16-2003 09:33 PM
