Output devices not available?
I purchased and downloaded PT10 yesterday. I installed it at work to test it, as the Mac here is top notch; a quad core 2x2.4mhz with 80GB RAM. OSX 10.7.
There is currently no device installed for audio, I just want to test it using the Apple display speakers. First, I had the "Line 1351 Error"so I pressed 'N'whiile opening and switched devices. It opens fine now. But, the main outputs are all greyed out (unavailable) and no sound comes out, obviously. When I click on the output of an audio track, there are 8 analog outs, all greyed out, as if it still looks for an 8 channel device which isn't there. How do I get playback from just the display? I've also tried the 'built-in output, same results; no sound and greyed out outputs. |
Re: Output devices not available?
Have you tried clicking "Default" in the I/O window?
And make sure that Core Audio is the selected audio engine. Inside a Pro Tools session>Setup>Hardware, or hold the N key while opening Pro Tools.
Thanks, PDJohns solution fixed it...
No output device selected in Studio Monitor Express, using Default Output (Mbox Pro). | Focuret | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-12-2014 07:33 AM |
how to HD IO output 2 word clock to 2 devices to sync | Rockman413 | Pro Tools TDM Systems (Mac) | 17 | 07-11-2012 01:15 AM |
Did HD IO output clock to external devices? | Rockman413 | Pro Tools HDX & HD Native Systems (Mac) | 3 | 07-06-2012 08:41 AM |
how to set up audio devices output in midi studio | budinski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-01-2011 02:27 PM |
O.T. Finding output levels for various devices | Jepse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-15-2003 09:44 PM |
