Old 08-05-2012, 07:40 AM
tamright tamright is offline
Default BCF200 Faders act wired
Hi All
i got Behringer B-Control - BCF200.
and i'm running pro tools 9 .. what happening is every time i start to write automation using the BCF200 Faders on touch or latch mode it go well for a second or 2 then it force it self to jump back to it's original position writing wrong automation.
any one facing this issue ??
any solutions ?
Thanks
Old 08-05-2012, 06:06 PM
Andrew. D Andrew. D is offline
Default Re: BCF200 Faders act wired
The faders on a BDF2000 are not touch sensitive so they will not work in either touch or latch because they don't know you are moving them.
I'm not sure but there maybe a key command that if you push while moving the fader will drop it in to record, I could be wrong though!!
You will need to be in "write" mode for it to work.
Mac Pro, Mid 2010 dual 3.33 Ghz, 64 Gig RAM
Mac OS 10.14.5
ProTools Ultimate 2021.6
HD Native PCIe
Apogee Symphony I/O
Avid HD I/O
192 I/O
Waves DLI
Apogee Mini Me
Mbox Micro
Old 08-06-2012, 05:24 PM
PD-John PD-John is offline
Like Andrew said, the faders on the BCF2000 aren't touch sensitive - so don't write automation in touch mode, you'll strain the fader motors.
Latch mode should work though, when you move the fader during playback, it should start writing automation until you stop playback. If Latch doesn't work so well, then just use Write mode.
Old 08-07-2012, 04:09 AM
Thanks guys for your replies, You were completely right.
I start using latch mode instead of touch .. it's working fine with me.
if you have time i have another Question .. what is the new touch/latch mode function does ? do u think i can use it by any means ?
thanks a lot for both of u .. you were very helpful.
Old 08-07-2012, 05:53 PM
Originally Posted by tamright View Post
What do you mean by new touch/latch mode?
Old 08-07-2012, 06:16 PM
Its not new, but when you are in touch mode and have finished your automation pass the fader will automatically latch to where you leave the fader e.g. when you take your hand off the fader it will stay where you left it rather than returning to where it was at that point in the mix, before the fader move.
Of course as we have pointed out this won't work with BCF2000 because of the lack of touch sensitivity.
Mac OS 10.14.5
HD Native PCIe
Apogee Symphony I/O
Avid HD I/O
192 I/O
Waves DLI
Apogee Mini Me
Mbox Micro
Old 08-10-2012, 08:42 AM
swift33 swift33 is offline
This problem made me sick and I wish I saw this topic earlier! thanks guys for the help!
Viagra Online
[IMG] code is Off
What can be re-Wired JonnyGinese 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-10-2007 12:59 AM
PLEASE help-BCF200- meric 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-18-2005 08:10 AM
Error using BCF200 .... Rob Eko Pro Tools M-Powered (Win) 0 12-01-2005 08:40 AM
Another test from the DOC - X73 wired backwards Carl Fuehrer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-21-2005 10:33 PM
I'm wired spicyitaliano Pro Tools TDM Systems (Mac) 2 01-23-2003 04:41 PM
