MIDI sync with PT 7.4 click track
I realize this subject has been posted before, but I'm just hoping for the correct fix.
I'm convinced there is some kind of lag in the PT 7.4 click track when using a MIDI controller to implement virtual instruments plug-ins. I have used Garage Band (to record sketches) and played along with a click track using a MIDI keyboard. Everything was perfectly in sync. However, PT 7.4 is a different monster. I play into PT using a MIDI keyboard while listening to the click, but the resulting recorded track is not quite in sync with the click track during playback. Can anyone provide a general summary about getting the perfect rhythm and sync between the click track and playback? Is this fixed in more current versions of PT? thanks |
Re: MIDI sync with PT 7.4 click track
During recording: Digi recommends to setup appropriate HW buffer size (Playback Engine -> HW buffer size).
It is NOT "set and forget setting". For recording it should be minimal (i am using 64 samples on 48kHz) and for mixing it should be enough to process effects (i am using 1024 samples on 48kHz). Again "HW buffer size" is NOT "set and forget" setting. Also, sometimes, i am using "Event Operations -> Input quantization". In this case MIDI notes align quantization grid during record. During playback: Quantize midi if MIDI notes not fit the "quantization grid". On LE system there is no "Plugin Delay Compensation", so probably you need to set it up manually...
macpro 2.6ghz, 4gb ram, osx 10.6.1, macbookpro 2.5ghz, 4gb ram, osx 10.5.8 mbox2pro, mbox2micro, emu1616, protools8le, reaper, logic express, axiompro49, padkontrol, rode nt2-a, lexicon mx300, uad2laptop r3, microQ, Albino3, impOSCar, Structure m1active 520 & sub gw s750, deq230, cx2310 |
Sync Grid Lines To Click Track | nickacuff1289 | Pro Tools M-Powered (Win) | 3 | 02-16-2012 04:13 PM |
Problems with song start, click track, and sync | Tbob | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-16-2010 06:26 PM |
Click out of sync when bouncing to audio track ...??? | Agentemo1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-17-2007 09:57 AM |
Sync drum machine to click track | espada3 | Pro Tools M-Powered (Win) | 0 | 08-09-2005 09:58 AM |
click midi sync | oslpchris | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 05-21-2002 06:44 AM |
