Hd core card fails digi test
My rig (HD2 ACCEL PCI-e) has been running a little funny lately. Ever since I downloaded the free DEVIL LOC plug actually- so I ran DIGITEST. My accel card passed , but the core card fails. Did it again. same result. is it because I'm connected to Rosetta 800? Will core cards always "fail" if they aren't connected to Avid I/O's?
Re: Hd core card fails digi test
Have you tried running it w/o it connected to the interface at all?
If it failed the loopback test that is normal. Most 3rd party interfaces do not support loopback sync and thus the test will fail on any cards in which you have these 3d party converters plugged in.
You have to read through the results. If any of the chips on the card have failed you have a problem. If it's only loopback all is well with your cards.
Joshua Aaron President/Chief Eng. AudioLot/AudioLot Studios Pro Audio Sales/Consulting http://www.audiolot.com Follow AudioLot on Facebook |
I had the same problem. I pulled off the cards and reinserted all of them and everything worked fine. In case doesn't work, insert the cards one at the time so you can find the one with the problem. If you are lucky the core card will work so you are not stuck.
I hope it helps! Max
Max Carola Recording Engineer - Mixer - Producer - Composer www.maxcarola.com Pro Tools Ultimate 2023.6.0 - Monterey MacBook M1Pro 10-16GB Dangerous Music Summing - Focusrite Dante Rednet2 - Amek/Neve, Focusrite, TC Electronics, Mytek DA, Apogee ADDA |
I guess I won't be installing that to my HD rig. I'll just keep it on the LE rig. Thanks for the heads up!
if the card has been removed or installed recently check to see if R35 is still attached, then follow by looking along that back edge to see if any of the Capacitors are missing just above R35 ( PCIe version )
for PCI version it's marked different but all components are identical locations these components missing will cause erratic behavior, working at times and not the next, or not at all I can fix this for a better $ than avid and no long waits on hold
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
I'm sending you a image of my digits results can you tell me if good or bad, or not to worry, cards both passed no problem then this morning re-done test and core failed,R35 chip is ok, nothing missing etc so confused s to what the issue is with it failing card is not that old and been working fine upto today, can you provide email I can send to thanks |
Need to test MIX CORE card | NannerPuddin' | Pro Tools TDM Systems (Mac) | 1 | 02-03-2012 02:25 PM |
How to digi test core card? | Raoul23 | Pro Tools TDM Systems (Win) | 2 | 04-29-2011 12:40 AM |
Core Card Failure? Peripheral Digital Loopback Test FAILED | digidesigner | Pro Tools TDM Systems (Mac) | 2 | 03-01-2011 04:28 PM |
Digi Test card failure | goom | Pro Tools TDM Systems (Mac) | 3 | 01-08-2006 04:11 PM |
001 fails sample rate test -41 | Cinemafixer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-01-2002 11:04 AM |
