Re: Limited to structure?
For some that's their only reason for coming here!
I work with amazing people who do incredible things. Founder of the Expert Sites. |
How do you put 4 patches on one thing of structure. And how do you designate between each one, like how do you use them separately? |
2) Go to Mix Window. Click on a blank insert and select Structure Essential. 3) You will see the default patch, which you can change, and it's channel is set at A1. Slightly to the right of this patch you will see Main and Browser buttons. Select Browser button. 4) Double click or drag another patch over to the patch list. You can max this out at 4 patches. 5) Create 3 new Midi Tracks. 6)For the first Midi track select the output button (this is in the mix window). Change this setting to Structure Essential 1 Port A and then choose channel 2. You should now hear the new instrument on that track. 7) Repeat with other Midi tracks. Select channel 3, etc. Let me know if you have any problems. |
I should add that if you add another instrument track and insert another instance of Structure, this will now be referred to as Structure Essential 2.
When you keep doing this you will max out at 12 midi tracks I believe. Unless there's something I don't understand. |
#16
Ok i havent tried it yet but that sounds really awesome. I hope i can figure it out becuase being able to have 12 different patches will help eminsely. Thank you selfextraction for the step by step instructions.
#17
Holy crap that is so great, thank you soooooooooo much. One little thing whenever i click say the midi 2 track i see the sound output on the intrument track is that how it is supposed to be? And again thank you so much.
#18
Also, you should go to this website and look under Structure sounds: http://airusersblog.squarespace.com/ you'll find many free sound patches for Structure here. You just need to copy these into the directory where your current patches are stored. This definately made me happy as I thought I was stuck with the sounds that came with Essential. Oh, and renumber your new patches to go with your current ones. |
#19
You are quickly becoming my favorite person on here. That is great that there are more patches because i do mostly hip hop type beats and i am sort of limited to what i can make because i don't want to use the same sounds over and over again.
So again thank you very much. |
#20
I heard even the full version of protools m-powered is limited, anyone know if that's true?
I am on a limited budget. | Doc K | General Discussion | 4 | 05-19-2009 06:04 AM |
Pro Tools HD limited to 4GB RAM??? | Dizzi45Z | Pro Tools TDM Systems (Mac) | 5 | 03-27-2009 11:57 AM |
Structure: Limited looping choices leaves me cold.. | sunsinger | Virtual Instruments | 6 | 08-05-2007 07:49 PM |
limited interfacing with M Box? | Bendrissa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-13-2003 04:24 PM |
Limited but COOOL | allenjames | Digidesign Hardware & Software | 0 | 12-10-2000 08:52 PM |
