#31
Duende Native AAX 64bit is out!
I don't know if the demo installers are the same as the release installers. What I would do if I were you is trash the plugin cache so Pro Tools has to rebuild it from scratch the next time it starts. Then see if the problem reoccurs. See here for instructions on how to do that. http://avid.force.com/pkb/articles/T...oting/en367983
#32
Re: Duende Native AAX 64bit is out!
what version number are you on?
#33
I installed v5.1.1 by the way.
Protools 12.4.0 :: MacPro 5,1 "Westmere" 2x2.4gHz 8-core 32GB Ram Sierra OS 10.12.6 :: Apogee Quartet |
#34
Hi If you follow this you will delete the plists aswell as cleaning up your databases on your setup: http://www.sweetwater.com/sweetcare/...s-preferences/ Best Regards Christopher
#35
Yeah I think the sweetwater page is easier to use- fwiw
#36
Did you notice any funniness with the GUI? I had a plug up, and some pots don't turn. Non responsive pT10.3.7
#37
I like the "double jointed" design, where there's a second knee that can essentially act as an upward expander (see image)
It's really good for dynamic instrumentation, especially when there's bleed or a slightly higher noise floor - you can even out the lower passages without changing the very quiet passages or squashing the loudest parts. Helps tighten things up without killing the overall dynamic range. The only other tools in my box that can achieve this are combinations of expander and compressor, and only if the expander is capable of ratios less than 1:1 (Waves C1 can, iZotope Nectar has a "floor" setting on its gate that will allow this to be done). I wish more dynamics plugins would allow curves like the SSL X-Comp.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
#38
I've never noticed this issue with any version of Duende and I've used them all since 1.0. I'm not even sure what could be causing that. Are you making adjustments with the mouse or with a controller of some sort?
#39
Yeah blue tooth trackpad
#40
Every knob/switch reacts for me (using mouse). |
SSL Duende Native 5.0.6 Now !!!!!! | abomeerza | AAX Plug-ins | 14 | 11-12-2014 11:00 AM |
SSL Duende Native is out now... :) | denka | Pro Tools 9 | 58 | 01-13-2014 02:26 PM |
Tell SSL, let them know we need Duende Native AAX ! | Gemylon | AAX Plug-ins | 7 | 05-20-2013 03:40 AM |
Duende Native &PT 10.2 | tele27 | Pro Tools 10 | 3 | 10-04-2012 02:05 AM |
New Duende SSL Native | M2E | Pro Tools TDM Systems (Mac) | 2 | 09-06-2010 05:33 AM |
